by mchavez Fri Mar 26, 2021 1:24 am
OK FULL STOP. the problem seems to be in my current limiter. When I tested my known working amp, I did it with the amp plugged into the wall. All voltages were fine. Today I tried the new amp on a regular household circuit...and voila! power levels all just fine!!!
I had tested the power supply and current limiter weeks earlier with my DVM and all voltages read just fine BUT the volt meter does not have any feedback (probably wrong term) into the circuit. The tube amps all leave a dull glow on the bulb which a volt meter does not do. the bulb is a 150 watt bulb. I believe this is the problem.
I now have the "new" amp playing and all biased correctly. I will keep using it for a week or so....whew! I was going crazy.
SORRY to put you all thru the diagnostic wringer but since I had tested the current limiter with the DVM and tested the power transformer thru the same circuit, I figured I had eliminated that as an issue.
What did I do wrong when building the current limiter? I will have to investigate.
