    Voltage readings with ws1T vta st120 at 113v
    Njrob
    Njrob
    Voltage readings with ws1T vta st120 at 113v Empty Voltage readings with ws1T vta st120 at 113v
    Post by Njrob Thu Feb 23, 2023 8:53 am
    Thoughts?
    Vta st 120 Tested at 113v
    Weber Copper Cap ws1T
    Pin 4 to ground - 400 - 425 volts AC (390)
    Pin 6 to ground - 400 - 425 volts AC (390)
    Any 6550/KT88
    Pin 1 to ground - approx .550 volts DC (depends on bias setting) (.470)
    Across pins 2 and 7 - 6.0-6.5 volts AC (6.4)
    (b+ startup peak at 520v )
    Pin 3 to ground - 470 - 500 volts DC (492)
    Pin 4 to ground - 470 - 500 volts DC (493)
    Pin 5 to ground - minus 50 to minus 60 volts DC (-49 )
    Pin 6 to ground – minus 50 to minus 60 volts DC (-50)
    Pin 8 to ground - approx .550 volts DC (.470)
    Quad cap - authenticap 550v/600peak
    (B+ startup peak at 520 settles at 499)
    (SQUARE) 480-505 volts DC (499)
    (HALF CIRCLE ) --- 470 - 500 volts DC (493)
    (FULL CIRCLE) 470 - 500 volts DC (492)
    (TRANGLE) ----400-430 volts DC (421)
    Central 12AT7 - Pin 1 or pin 6 to ground > 130 - 160 volts DC (155)
    Two outer 12AT7's – Pin 1 or pin 6 to ground > 255 – 285 volts DC (265)
    Any 12AT7 - across the two incoming heater wires > 6.0-6.5 volts AC (not measured)
    "-50 VAC" on driver board > 48-55 (52)
    "B+" on driver board > 400 - 430 (421)
      Current date/time is Sun Apr 28, 2024 12:36 am
