Reviving this older thread. My line voltage goes from 118-122 (have seen 113 VAC to 126 VAC) so I have to chase my Variac all the time. Has anyone found any more recent solutions? One post suggests that running too far under voltage is bad for the tubes. I have the variac set for the highest swings so I don't pop the multi-cap on my ST-120.
+9
New2Tubez
ArlanB
cci1492
bluemeanies
jwb474
wildiowa
13 posters
Voltage regulator vs VARIC vs Power Conditioner
ggriswold- Posts : 2
peterh- Posts : 1836
One solution is to install an UPS , I have a Smart-UPS 1500. It's a straight wireggriswold wrote:Reviving this older thread. My line voltage goes from 118-122 (have seen 113 VAC to 126 VAC) so I have to chase my Variac all the time. Has anyone found any more recent solutions? One post suggests that running too far under voltage is bad for the tubes. I have the variac set for the highest swings so I don't pop the multi-cap on my ST-120.
when the input voltage within limits, outside limits it will synthesize AC.
I do use it for my computers however as the electrical net in sweden is fairly good and
power outages is less then one per year. Mains voltage fluctuates ( today) between 233V and 240V
which is fully acceptable for my stereo.
I have a UPS but doesn't clamp swings adequately. It is a CyberPower CP1000PFCLCD PFC Sinewave UPS System, 1000VA/600W.
Apparently the older ones had a button that took you into a menu that you could set high/ low - this doesn't. Even using the software attached to the UPS won't let you clamp until the line voltage reaches 138 VAC. Don't have a grand to spend on the other suggestions.
Last edited by ggriswold on Mon Aug 24, 2020 11:44 am; edited 1 time in total (Reason for editing : Clarify)
Hops- Posts : 85
JWB474, Who manufactures or sells the lower two items you pictured ( looks like Variacs that regulate output voltages independently of input voltage ) . Do you have names or model numbers for them?
ggriswold likes this post
