    5v4GA Rectifier Tube
    rodulfo23
    5v4GA Rectifier Tube Empty 5v4GA Rectifier Tube
    Post by rodulfo23 Sat Oct 20, 2018 5:45 pm
    Hi! All,
    Is there anybody tried or are using this (5V4GA) rectifier tube on VTA ST-120 without issues? I have a couple of this
    which I got from Ebay 3 years ago and used them with Hagtech Clarinet Preamp and Cornet 2 phono preamp for less than 30 hours and found them better sounding than the stock 5Y3GT.
    Here is the link;(https://www.worthpoint.com/worthopedia/5ar4-rectifier-tube-nos-mil-philips-112414496)
    5v4GA Rectifier Tube 5ar4-r10
    Thanks!
    Big Harry
    5v4GA Rectifier Tube Empty Re: 5v4GA Rectifier Tube
    Post by Big Harry Sat Oct 20, 2018 5:53 pm
    I don't recommend using a 5V4 to replace a 5AR4 in an ST120 as the 5V4 while they look similar to a 5AR4, they aren't, especially in the voltage rating department.
    solderblob
    solderblob
    Post by solderblob Sat Oct 20, 2018 9:44 pm
    rodulfo23 wrote:Hi! All,
    Thanks!
    I'm using a Hagerman Cornet phono preamp (original version) which uses a 5Y3GT rectifier.  I recently decided to retube since it's been +/- 15 years since I built the amp.  I replaced the 12AX7s with some JJ tubes.  Very detailed but harsh.  So I put the original 12AX7s back in.
    So now I'm using the original tubes but with a JJ 5AR4 rectifier and it sounds OK, i.e., as before the retubing.  But would you recommend I try a 5V4?
    Dave
    Big Harry
    Post by Big Harry Sun Oct 21, 2018 8:34 am
    Both the 5AR4 and 5V4 have a much lower voltage drop across them than the 5Y3 which will raise the B+ voltage maybe 20 or 30 volts. In a preamp, I would use a 5Y3 if that is what was specified for it. 5Y3's are readily available either NOS or good used and are fairly cheap.
    solderblob
    solderblob
    Post by solderblob Sun Oct 21, 2018 9:29 am
    Big Harry wrote:Both the 5AR4 and 5V4 have a much lower voltage drop across them than the 5Y3 which will raise the B+ voltage maybe 20 or 30 volts. In a preamp, I would use a 5Y3 if that is what was specified for it. 5Y3's are readily available either NOS or good used and are fairly cheap.
    Thanks, good info.  Hagerman's instructions indicated that either 5Y3 or 5AR4 could be used.  I have the 5AR4 in there now so I'll use it for a while.  I can't really hear any difference.
    Tubes4ever
    Tubes4ever
    Post by Tubes4ever Sun Oct 21, 2018 10:17 pm
    The 5v4GA is rated for 175mA of current output. The output tubes on the ST120 when biased at 50mA each is pulling 200mA total and that's not taking into account the current draw of the VTA driver board which is at least another 25mA.
    So no, you can't use the 5V4GA tube with a ST120 amp. At least and have the tube last very long.
    Jim McShane
    Post by Jim McShane Tue Oct 23, 2018 7:35 pm
    Thanks!
    The tube in the picture is NOT a 5V4GA. It is a 5AR4 JAN Philips tube. The US military had a need for 5V4GAs and Philips could not supply them (and didn't want to tool up to produce them) so they re-labeled some 5AR4 tubes as 5V4GAs. The 5AR4 can sub safely for a 5V4GA but not the other way around.
    A lot of people say it isn't a real 5AR4 - but it absolutely is. Compare the plates on the "5V4GA" to a 5AR4 and you'll see they are absolutely identical. Regardless of what is printed on it that tube is a 100% REAL 5AR4. You can use it wherever a 5AR4 is appropriate - including the ST-120.
    rodulfo23
    Post by rodulfo23 Tue Oct 23, 2018 8:16 pm
    Thank you! Jim McShane for the very informative reply and info.
    Actually, I saw and took pictures of the Sylvania 5AR4/GZ34 etched on tube sold
    on Ebay as I write this reply. I just can't post the pictures. It appears the same
    plate and construction as the Philips ECG "mislabled" as 5V4GA.
      Current date/time is Fri Apr 26, 2024 7:55 pm
