+26
turbotoy
bcinnamon
Sutton
scombridae
cduarte
evilfij
RockyAM
dynacophil
anbitet66
River
Gregg357
Luddite
tubehd4life
xlr8
DesignInc
davidness
avi.inc
Corona
natoe
Falcon4646
JunkyJan
baddog1946
30 posters
    Prototype 125 watt monoblock tube amplifier KIT
    Luddite
    Luddite
    Prototype 125 watt monoblock tube amplifier KIT - Page 5 Empty Re: Prototype 125 watt monoblock tube amplifier KIT
    Post by Luddite Mon Apr 04, 2011 12:24 am
    Gregg357 wrote:Bob,
    I'm working on my M-125 build and am confused about the method of securing the quad cap to the chassis. The manual says to twist the tabs 1/4 turn. I feel if I were to twist them they would tear. They don't look like they could endure a 1/4 turn twist. It looks like they should just be bent back up toward the chassis, at a 90 degree angle to the quad cap itself. Please give me your thoughts. Lastly, what's your preferred method for me to ask my questions as I go through the build, here on the forum or direct via email? Thank you.
    Gregg
    Gregg,
    The tabs are designed by the manufacturer to be twisted, and they will not break. Bending the tabs over will not secure the capacitor properly to the chassis.
    Best Regards,
    Charlie
    Post by Bob Latino Mon Apr 04, 2011 7:08 am
    Gregg,
    Charlie is correct and so is the manual. If you just give those tabs maybe a 1/8 to a 1/4 turn they will usually lock to the chassis securely. If the quad cap seems loose OR anyone has had to remove and reinstall a quad cap, you can also place a small dab of epoxy over each tab after the twist.
    If you have a minor issue with a kit instruction, you are probably better off to Email me directly for a quicker response.
    Post by Bob Latino Wed Apr 13, 2011 11:41 am
    Prototype 125 watt monoblock tube amplifier KIT - Page 5 M-125driverboardswithparts1024
    I had someone Email me and request a closer look at the M-125 driver boards so I thought it would be a good idea to just post a photo of a pair of the PRODUCTION driver boards. They are of the same construction as the VTA ST-70 driver board with no open solder traces on either the top or bottom of the board. These boards have plated through holes and components may be place on either the top or bottom of the board. (NOTE on 2/11/19 > These are the older non CCS boards. As of late 2014, all VTA M-125 boards now have a small LM334 integrated circuit on board to provide a constant current source in the tail of the phase splitter.)
    Sutton
    Prototype 125 watt monoblock tube amplifier KIT - Page 5 Empty Picture of the back
    Post by Sutton Sat Apr 23, 2011 11:59 am
    Hey Bob,
    How about a picture opf the back of the board, os we can see how the jumper wire and some of the other things are suppose to look. Thanks,
    Sutton
    Post by Roy Mottram Fri May 06, 2011 1:00 am
    Bob and I had a special run of these PCBs made specifically for his M125 monoblocks,
    but they are identical to the MK3 mod boards that I also sell.
    But just to be clear, the MK3 boards (which you can use to build ANY P-P tube amp)
    are NOT silkscreened (the white parts outline) and solder masked (the green color)
    but are otherwise absolutely identical, even made by the same PCB supplier,
    here is a photo of the bottom side:
    Prototype 125 watt monoblock tube amplifier KIT - Page 5 MK3-133
    Sutton
    Post by Sutton Mon May 16, 2011 11:11 am
    Just surfing eBay and saw that Captain Bob's Electronic Emporium is now offering a complete set of tubes for the VTA M-125 mono blocks. He is including a matched quad of Tung Sol KT-120 output tubes, a pair of Electron Harmonix 12BH7A gold pin driver tubes, and the Weber GZ68 Copper Rectifier for $279.97(now 265.97 on 5/19/11) per amp. This may save the shipping from all the different sources putting all the tubes together yourself (as I did). I bought my two quads of KT-120 tubes from Captain Bob, and am very happy with them. His seller ID is ak6r and the item number now is 380332534835 . I am in no way endorsing or have nothing to gain in reporting this. I am simply informing the owners and prospective owners of these wonderful amps of the option to get all the needed tubes and rectifier from one source.
    I have finished only one of my M-125 amps and it is very glorious. I just have to find the time to finish the other one. For those who are on the fence with regard to these mono blocks, I can whole heartedly give them a huge thumbs up. I own many Fishers, including an SA-1000, a Marantz 8B, a McShaned Harman Kardon Citation II, a Pair of Bogen MO-100's, a pair of Quicksilver 8417 mono blocks and many other vintage and "modern" solid state amps. The VTA M-125 is at the top of the crowd. For the money, you can not buy a better pair of mono blocks. Period. Get off the fence and get the soldering iron in hand. These really are THAT good.
    Last edited by Sutton on Thu May 19, 2011 11:51 am; edited 1 time in total (Reason for editing : updated pricing)
    Sutton
    Prototype 125 watt monoblock tube amplifier KIT - Page 5 Empty Any other Driver Tube Types
    Post by Sutton Tue May 17, 2011 3:59 pm
    In my previous post I failed to thank Bob for all his help and hand holding during my build of the M-125. He is very gracious and patient with folks new to the kit thing, and I certainly asked some really dumb questions in hindsight. Thanks you, your support was invaluable. And I too, wonder when you sleep. Seemed you were always there to answer questions and steer me in the right direction. HATS OFF TO BOB!!!
    Question--has anyone tried any other tubes in the driver board,? I have tried 12AU7 and 12BH7A, and I really liked the gain from the 12AU7, but I did not like the distortion and seeming lack of linearity. I love the 12BH7A tube, but it seems to be a little lacking in gain...seems like the M-125 is sitting there idling waiting for more to open up and do it's thing. Has anyone tried any other tubes, in either rposition in the driver board? How about the E80CC? Will it work in either position? Tungstram or Amperex? How about Russian tubes? Any suitable subs for the rectifier in Russian military tubes? Something from SkyLab or something?
    I'd love to hear from Bob and all users as to what tube types might work, and what your observations might be. Brands, years of manufacture, anything...
    Thanks again to Bob for a great amp at an affordable price.
    Post by Bob Latino Tue May 17, 2011 5:18 pm
    Hi Sutton,
    It is difficult to evaluate a single monoblock amp when the amp is supposed to be working with a "partner" in a stereo environment. The single amp may sound lacking in some respects playing alone since we are so used to the 3D stereo effect of two amps (or the two channels of a single stereo amp) playing together. When you complete the second amp and have them playing together you will really hear what these amps can do.
    As for the 12AU7 or 12BH7 tubes and which one you can use. You can use either but you probably won't hear much difference between them. The 12BH7 does have a little less gain but I can't really notice any difference at all in "gain" between the two tubes. The front voltage amplifier driver tube will have the most influence on the sound of the M-125. In that position a Mullard CV4003 (12AU7 equivalent) is my favorite tube so far for a very smooth and accurate mid range and vocals. The RCA "clear top" 12AU7 is also very good and may even offer a little more "air" to the top end of the amp than the Mullard. In the rear phase splitter/inverter tube (IMHO) you should use a 12BH7. A 12BH7 has larger plates and on paper can swing voltages better than a 12AU7. I haven't heard much difference in any of the 12BH7's (RCA, GE, ElectroHarmonix) that I have used in the rear position on the M-125.
    Prototype 125 watt monoblock tube amplifier KIT - Page 5 Empty Better M-125 photos
    Post by Bob Latino Tue May 24, 2011 5:21 pm
    I finally found the time to take some better photos of an M-125 amp with the green production driver boards. The other photos contained the lemon colored prototype driver boards. Photos below ... NOTE - AS of January of 2017 all VTA amps now come with THREE post output binding posts and may be set up for any TWO output impedances (4 and 8 ohm or 4 and 16 ohm or 8 and 16 ohm)
    Prototype 125 watt monoblock tube amplifier KIT - Page 5 M-125Front_1024
    Prototype 125 watt monoblock tube amplifier KIT - Page 5 M-125rear_1024
    Prototype 125 watt monoblock tube amplifier KIT - Page 5 Driverboardcloseup
    davidness
    davidness
    Post by davidness Wed May 25, 2011 9:06 am
    Bob,
    I notice in the pictures that you've paired the quad of KT-120's with the Weber WZ68. I believe you had good success using the Mullard GZ33 rectifier when used with the KT88's. Do you believe the GZ33 to be "too small" when used with the KT120's?
    Post by Bob Latino Wed May 25, 2011 9:20 am
    Hi David,
    The Weber WZ68 solid state rectifier is better for the M-125 if you play the amp loudly and if the speakers you have are inefficient and/or difficult to drive.
    The GZ33 and GZ34 are alternate (tube) rectifiers that you can also use with the M-125. They work better with more efficient speakers. The Mullard GZ33 works well in the M-125's but, as you know, these tubes are expensive. If you want to alternately use a tube rectifier in the M-125's, I recommend any GZ34 in place of the Weber WZ68.
    bcinnamon
    bcinnamon
    Prototype 125 watt monoblock tube amplifier KIT - Page 5 Empty M-125 Amp Experience
    Post by bcinnamon Mon Jun 20, 2011 9:10 pm
    Before I started this project I shopped around for a 100w+ tube amp. Even pre-owned amps were at least twice the price, so I took the plunge. I figured that even if my “project” worked OK it would sound better to me than anything else I could buy.
    But I was blown away; I felt like that guy in the Memorex ad. I’ve been listening continuously to my collection of Jazz and rock — especially tracks with sax, trumpets and guitar. Even when I crank it up to 11 the sound remains pure. My teenage kids definitely preferred the tube amp sound -- and that is from the mp3-earbud crowd! Imaging is uncanny, the tone reminds me of a perfectly tuned bell, and I hear every nuance of brush strokes and guitar slides and audience coughs in the background (apologies to Keith Jarret in advance). The saxophone on “Jungleland” is especially haunting tonight ;(
    I'd attach some photos if I knew how. Suffice it to say that my pictures look just the same as Bob's. Most importantly, the whole build process went quickly and smoothly. Bob's instructions, amp design and suggestions are all top notch.
    Sutton
    Post by Sutton Sat Jun 25, 2011 9:56 am
    I have found that shopping eBay UK is the way to go to find less expensive GZ33 tubes. I recently bouht a brand new pair of Mullards shipped from London for $75.00. You will have to look and wait and perhaps correspond with the seller about shipping to the USA, but this particular tube is not as highly sought after in the UK and bargains CAN be had.
    RockyAM
    Post by RockyAM Thu Jun 30, 2011 1:15 pm
    Hi Bob, It was on the strength of building your VTA ST-70 kit about 2 years ago for my office system that I purchased a pair of your M-125 monoblock kits last month for my main system. Let me say right off - the assembly instructions for the M-125 were excellent. (as were the instuctions on the VTA ST-70) The pictorial was really helpful and there was no question of where a part or wire went. Everything fit perfectly and there were no missing parts or extra parts. The way that the amp is laid out you can tell that much thought went into the design. Both amps started up without issue although one of the 12BH7's that I had purchased was a little noisy. As per your suggestion by Email I swapped that tube with the one behind it and the noise went away. I Emailed the Ebay seller about the noisy tube and I am going to send that tube back to him and he will send me another. I also got the Tung-Sol KT120 output tubes from him. The rectifier is the Weber WZ68 that you recommended.
    The M-125's replaced an older Adcom GFA-555 200 watt per channel solid state amp that I had used since the 1990's. I don't know how the M-125's do it but they sound just as strong at 125 watts as the Adcom at 200 watts. With respect to the sound everything about the M-125's is better than the Adcom amp. The soundstage is wider and deeper on the M-125's and each instrument and vocalist is more pin point as to its location as compared to the Adcom amp. I have also tried the triode vs. the pentode configuration but have not really formed an opinion as yet as to which one I prefer. The amp is still breaking in and only has about 50 hours on it as I write this. I have noticed subtle improvements since the amps were new. In comparison to when the amps were new, the sound now seems smoother and more articulate. Vocalists and acoustic instruments like a sax or a trumpet just sound more like the real thing in comparison to my old Adcom amp. Thanks for offering this amp kit. I don't think that there is another 100+ watt monoblock tube amp kit out there with a better price/performance ratio. RockyAM
    Post by deepee99 Fri Jun 08, 2012 2:18 pm
    Hello all. Please forgive if this has been addressed in another thread and I missed it, but in casting about for tubes for the M-125s I am given the option of selecting (for quad-matched 6550 output tubes) either "early", "late" or "average" distortion. Could someone advise me on this? Many thanks.
    -dave-
    Post by Bob Latino Fri Jun 08, 2012 3:18 pm
    deepee99 wrote:Hello all. Please forgive if this has been addressed in another thread and I missed it, but in casting about for tubes for the M-125s I am given the option of selecting (for quad-matched 6550 output tubes) either Could someone advise me on this? Many thanks.
    -dave-
    Hi Dave,
    That "early", "late" or "average" distortion is because you are looking at 6550 tubes on a GUITAR AMP web site. Those factors are important to users of guitar amps who use varying amounts of actual "distortion" in their amps to get a certain type of sound for their guitar amp. These early/late/average characteristics have no real bearing on stereo/hi-fi use. For good quality and well tested tubes for the M-125 check with Jim McShane at > jimmcshane@prodigy.net.
    You can also check > The Tubestore online
    or
    The Tube Depot online
    Post by deepee99 Sat Jun 09, 2012 7:23 pm
    Bob, as usual, thank-you for the quick info. It's a joy to meet you folks and this community.
    -d-
    RockyAM
    Post by RockyAM Tue Jun 12, 2012 4:31 pm
    Hey Bob, I had a friend listen to my M-125 monoblocks and he is interested in building a pair. He wanted to see what the inside wiring looked like. I lost your Email address so the only way I could contact you is through the forum here. Any way you could post a photo of the inside wiring? I guess I could have pulled the bottom cover off one of my amps but they were hot and he had to leave anyways. Thanks. RockyAM
    Post by Bob Latino Tue Jun 12, 2012 6:05 pm
    Sure - Below is a photo of the inside wiring of two M-125 monoblock amps.
    Prototype 125 watt monoblock tube amplifier KIT - Page 5 2_X_M-125_wiring
    Prototype 125 watt monoblock tube amplifier KIT - Page 5 Empty More dumb M-125 questions . . .
    Post by deepee99 Tue Jun 12, 2012 7:37 pm
    That is one beautiful build. My compliments to the assembler, whose handle I cannot recall from another thread. Also, to die for were those two custom wood-framed mirror amps that fellow built in Texas or wherever. JT something or other . . . egads! stark beauty. I would not attempt the same at home.
    Thank-you for the referral to Jim McShane for tubes. What a nice guy! He has some NOS GE 12BH7s for the front-end of the M-125s; I grabbed two sets but presume he has more if anybody's interested.
    Last I could tell, you still lean toward the Tung-Sol K-120s. But you doubt you and the folks around here have rolled a lot of tubes through the M-125s since then. Jim likes the Genalex KT-88s in your amp.
    Am in no rush for an answer as the kits won't get here till Monday and in my aulde age I'll probably be the summer putting them together, but are you still enamoured with the KT-120s? This question is informed with my desire to let the output tubes loaf a little bit rather than maxing them out.
    Selah.
    p.s. Your other recommendation, that I purchase new speaker wire from Blue Jeans Cable, also paid out. Got the roll of Canare wire almost before I ordered it. Good guys.
    Last question I would toss up. Back in my good old days, you kept your coax short and your speaker ledes long. Now, it appears the opposite is true. Could someone enlighten?
    Cheerio, and thank-you for bothering with these seemingly amateurish questions.
    turbotoy
    Post by turbotoy Tue Jun 12, 2012 8:46 pm
    The one above is mine, thanks! I'm running the KT-120s with NOS Sylvania 12BH7a tubes on the driver boards. I have nothing to compare them to, but I also have no burning desire to try anything else at the moment, I'm just enjoying listening!
    Post by deepee99 Tue Jun 12, 2012 9:34 pm
    turbotoy wrote:The one above is mine, thanks! I'm running the KT-120s with NOS Sylvania 12BH7a tubes on the driver boards. I have nothing to compare them to, but I also have no burning desire to try anything else at the moment, I'm just enjoying listening!
    Works for me! Thanks
    d
    Post by deepee99 Tue Jun 12, 2012 9:36 pm
    BTW, thought about selling those assembly stands, or at least renting them?
    turbotoy
    Post by turbotoy Wed Jun 13, 2012 8:54 pm
    deepee99 wrote:BTW, thought about selling those assembly stands, or at least renting them?
    Naah, it's just a small piece of plywood with 3 uprights. Anything remotely similar would work. It would cost more to ship than to find locally from some scrap. That said, I've been building my house for the last 6 years, so there's plenty of scrap lumber around and the saws are always setup. I probably wouldn't have used trim grade American cherry for the uprights if I hadn't been able to pull pieces that were almost the perfect size right out of the scrap bin!
    It's kind of analogous (albeit much more trivially) to me reading through Morgan Jones' book and longing to have piles of ex-BBC output transformers, attenuators, tuning caps, etc. lying around to execute some of the procedures that he describes, with the implication that everyone has such parts lying around the house.
    Post by Bob Latino Fri Jun 29, 2012 11:02 am
    Here is a better photo of the inside wiring of a VTA M-125 monoblock with the newer revised Supplementary Cap Module (SCM). This amp was built by VTA amp technician Sal Brisindi ... If you need upgrading or repairs done to your Dynaco tube amp or preamp get in touch with Sal at > Salb203(at)aol(dot)com
    Prototype 125 watt monoblock tube amplifier KIT - Page 5 M-125wiring_3
      Current date/time is Sat Sep 07, 2024 10:03 am
