by Peter W. Fri Feb 15, 2019 3:23 pm
I will qualify this post by stating right up front - I have not heard these particular speakers!
That being written, on speakers in general, especially (relatively) tiny and (relatively) inefficient ones:
a) So much depends on the size of the room, placement of the speakers and the taste and preferences of the owner.
b) As the manufacturer, following the wretched practice common to today, gives a frequency range, but not a dB range, it is likely that these speakers will be thin at the bass. If they are anything like the 1.5, they will be down about 10 dB at 45 HZ as the 1.5 is down 10 dB at the bottom of its claimed range (50 HZ).
c) 35 watts will give 103.4 dB without clipping. The manufacturer suggests a minimum of 50 watts (105.9 dB), with the understanding that the transient associated with a snare-drum rimshot is 120 dB.
All that being written, and having heard the 1.5s, they are fine speakers for what they are. Their midrange is excellent and transparent. The highs are not strident and feel accurate. I would not have them, as I would not be happy having to go to the effort of adding a sub-woofer just to get full sound, and knowing that all my listening venues are either too small or far too large to do them justice.
As with speakers, especially - do not purchase without an audition, better, an audition in your listening room that extends for some time.
Best of luck. But from the statistics and 30,000 feet, this does not look like a very copacetic combination.
