    Rectifier troubleshooting
    steve46
    Rectifier troubleshooting Empty Rectifier troubleshooting
    Post by steve46 Sat Mar 23, 2019 5:49 pm
    I just completed the yellow-sheet mod on my ST-70. Now, no sound, and the rec tube isn't heating up. I've already checked for cold solder joints. Can I assume the tube has gone south and I need to order a new one? Or would a failed tube still "light up"? The amp was working perfectly before I "improved" it. All other tubes look fine. Should I revert the diode mod and then see if it will work?
    mijohn
    Rectifier troubleshooting Empty Re: Rectifier troubleshooting
    Post by mijohn Sat Mar 23, 2019 7:15 pm
    Double check your wiring especially the orientation of the two diodes, the ends with the silver bands are connected to pins 4 and 6.
    steve46
    Post by steve46 Sat Mar 23, 2019 7:34 pm
    I'm sure the orientation is correct. Not as sure of my soldering technique. My eyes aren't as good as when I originally built it. I'll have another go at it.
    New2Tubez
    Post by New2Tubez Sat Mar 23, 2019 10:39 pm
    Another thought-
    Aren't those diodes sensitive to being overheated during soldering? Did you test them? I did mine but don't recall the right number but I got it off the interweb. I was worried that I may have fried mine.
    steve46
    Post by steve46 Sat Mar 23, 2019 10:49 pm
    If they're subject to get overheated, that might be my problem. I cut the leads fairly short and got them pretty hot, I imagine. I will try to test them tomorrow, or maybe just replace them. Thanks.
    New2Tubez
    Post by New2Tubez Sat Mar 23, 2019 11:32 pm
    I think I found it here:
    https://www.youtube.com/watch?v=gzh8ICLMXzQ
    I did test in circuit btw. If I did this wrong, someone let me know but they're working.
    mijohn
    Post by mijohn Sun Mar 24, 2019 4:01 am
    This video is also very helpful for testing diodes.
    https://www.youtube.com/watch?v=BXOS5czCb3Q
    steve46
    Post by steve46 Sun Mar 24, 2019 12:13 pm
    Thanks for the links on diode testing. I tested them, and both are good. Next, I jumped accross the two diodes and turned on the power -- the tube lit up. I have isolated the culprit connection and tried reflowing the solder, but still not working. Now I know the tube is probabley alright, and where the problem lies. Hopefully I'll be back in business later today.
    Thanks for your suggestions.
    Tubes4ever
    Tubes4ever
    Post by Tubes4ever Sun Mar 24, 2019 10:30 pm
    The diodes shouldn't have any effect on whether the tube lights up. Are you sure you have the diodes hooked to pins 4 and 6 and not 2 and 8?
    steve46
    Post by steve46 Sun Mar 24, 2019 10:59 pm
    You are exactly right. I hate to admit I was was working on the wrong pins. I have no "red leads" as shown on the yellow-sheet (they're all four white). I was so certain I was working on the correct pins but when I realized my mistake I corrected the wiring with no issues whatsover. Embarrassed but pleased to get the problem resolved.
    Tubes4ever
    Tubes4ever
    Post by Tubes4ever Sun Mar 24, 2019 11:04 pm
    steve46 wrote:You are exactly right. I hate to admit I was was working on the wrong pins. I have no "red leads" as shown on the yellow-sheet (they're all four white). I was so certain I was working on the correct pins but when I realized my mistake I corrected the wiring with no issues whatsover. Embarrassed but pleased to get the problem resolved.
    Glad to hear it! We've all made similar mistakes at one point or other.
      Current date/time is Fri Apr 26, 2024 6:31 pm
