Hey there folks. Electronics/tube newbie (tube nube?) here. Here's my tale of woe. Tips and tricks welcome! Recently got my hands on a great looking ST-70. After adding a fairly beat up PAT-5 to the mix, the left channel on the ST-70 died on me.
i tested by going direct from multiple different sources direct into the amp, and only ever got audio from right side.
I replaced the RCA cable.
I also swapped the speakers.
still dead left.
The problem is clearly within the amp, maybe the transformer? For what its worth, the brave soldier didn't go down without a fight. My clearly quite sickly PAT-5 decided to go berserk, and there was lots of loud POP POP POP etc as I dove across the room to power it all down. alas.
I upgraded the PAT-5, replacing dirty jacks, boards, ground screw and such. The PAT-5 works great now, so it seems (with a different amp).
Now, my poor old ST-70 was bone stock, so i figured I might as well do some upgrades and perhaps my problems would go away and my left channel would come back. So I got myself a new choke, multi-cap and replaced the selenium rectifier. see below photo...
pic of upgraded guts
(you'll notice a few new-ish looking white wires in there, I had to replace a few of the aging black wires that broke off in my hand, or were just too bloody short for easy re-installation).
Now, after my upgrades, when the unit powers up, I only get quiet, crackly audio from the right channel, and nothing from the left. Boo. i made it worse! yayyyyy.
I went over all my solders, and although they are a little sloppy/heavy-handed (i am a newbie after all), i THINK I have everything in the right place. i went over every connection from 1-23, and all seem to go to the right places.
One questionable area for me is the Choke. Comes with two black cables, one goes to one foot on the multi-cap, the other goes on a different foot on the multi-cap, right? the diagram gets a little crowded there, so maybe i gooched that? Is one supposed to ground? Would it matter which black cable goes where? how the heck can i tell the difference between them then?
Of course, the other questionable area is my new rectifier setup. That seven lug unit seems okay, but maybe I did the caps backwards?
any suggestions of voltages/ohm-ages to measure would be welcome.
still dead left.
