    Attentuator for ST70 VTA
    evgenibgr
    Attentuator for ST70 VTA Empty Attentuator for ST70 VTA
    Post by evgenibgr Wed Oct 23, 2019 9:04 am
    In my ST70 the VTA uses volume control "dact type 21". I am thinking for someone better.
    I wonder that the TKD 2P-2511S will put in this place without a mechanical problem?
    Here is datasheet of this TKD.
    http://www.acoustic-dimension.com/tkd/2P2511.pdf
    Attentuator for ST70 VTA 20130110
    Attentuator for ST70 VTA 20181010
    Hops
    Attentuator for ST70 VTA Empty Re: Attentuator for ST70 VTA
    Post by Hops Thu Oct 24, 2019 4:34 am
    What is it that you don't like about the stepped attenuator? What benefit do you expect out of the change? Generally, stepped attenuators are thought to be an upgrade to potentiometers rather than visa versa. If the stepped attenuator has failed, I would replace it with a new stepped attenuator of the same model.
    evgenibgr
    Post by evgenibgr Thu Oct 24, 2019 4:49 am
    Hops wrote:What is it that you don't like about the stepped attenuator?   What benefit do you expect out of the change?    Generally,  stepped attenuators are thought to be an upgrade to potentiometers rather than visa versa.   If the stepped attenuator has failed,  I would replace it with a new stepped attenuator of the same model.
    i use a shunt circuit to connect the attenuator. The problem is that I have a crack noise at rotating the volume. The "potentiometer" mentioned above is actually stepped attenuator. TKD 2P-2511S is with stepped action (21 steps).Attentuator for ST70 VTA P2511-19
    Attentuator for ST70 VTA P2511-20
    Attentuator for ST70 VTA P2511-21
    Hops
    Post by Hops Thu Oct 24, 2019 7:00 pm
    I installed the Tubes for HiFi unit to my VTA-120 . I think it is the same DACT-21 as yours. Mine is quiet and works well. I would order a new one from http://www.tubes4hifi.com/bob.htm. , and just replace your existing unit.
    colin86325
    Post by colin86325 Fri Oct 25, 2019 3:53 pm
    What kind of transformer covers are those?
    evgenibgr
    Post by evgenibgr Fri Oct 25, 2019 4:46 pm
    colin86325 wrote:What kind of transformer covers are those?
    That not only covers. Inside have amorphous core transformers Lundahl.
    colin86325
    Post by colin86325 Fri Oct 25, 2019 4:59 pm
    Very nice, which model Lundahl? Did you find an improvement over the A470?
    evgenibgr
    Post by evgenibgr Sat Oct 26, 2019 3:05 am
    colin86325 wrote:Very nice, which model Lundahl?  Did you find an improvement over the A470?
    I think the transformer is LL1663AM.
    Improvement is huge, very modern sound.
    I dont use negative feedback, but use this choke 😉
    Attentuator for ST70 VTA 15720711
    colin86325
    Post by colin86325 Sun Oct 27, 2019 12:16 am
    Man, I wish I had the money to experiment, because those would be on my short list.
    I'm glad you are enjoying the sound.
    If I do build a new  amp I would like to use the driver board from this site with a pair of these for my solid state power supply:
    https://neurochrome.com/products/21st-century-maida-regulator
    tubenutr
    tubenutr
    Post by tubenutr Mon Nov 04, 2019 8:27 pm
    evgenibgr wrote:In my ST70 the VTA uses volume control "dact type 21". I am thinking for someone better.
    Personally, I prefer the dact type 21 to any reasonably priced attenuators. They track incredible well and channel balance is very, very good.
      Current date/time is Wed May 08, 2024 9:59 am
