    Weird problem with MK-III amplifier
    ViperZ
    ViperZ
    Weird problem with MK-III amplifier Empty Weird problem with MK-III amplifier
    Post by ViperZ Mon Mar 16, 2020 9:11 pm
    So while exploring my monoblocks for cause of humming (surprisingly apparently bad ground connection between PCB and chassis), I screwed something up with one of them.
    One of them now has serious distortion on the output. I reflowed all solder joints and cleaned the tube sockets - that's all I did.
    Anyway, output of first amp cascade looks good, goes to input is triode phase splitter. Here is where it gets weird. Pin 3 output looks great, whereas pin 1 output of tube is all messed up - bottom of the sine wave is distorted significantly. Swapping the tube doesn't help - output of pin 1 is weird and different with another good 6AN8 tube.
    Tube socket looks good visually. I desoldered it, all 9 pins have good continuity through the socket body. I don't have any spare new tube sockets to try unfortunately.
    What could be causing this problem? Thank you.
    Weird problem with MK-III amplifier Empty Re: Weird problem with MK-III amplifier
    Post by peterh Tue Mar 17, 2020 3:11 am
    ViperZ wrote:So while exploring my monoblocks for cause of humming (surprisingly apparently bad ground connection between PCB and chassis), I screwed something up with one of them.
    What are the DC voltages compared to the voltages in the manual ?
    ViperZ
    ViperZ
    Post by ViperZ Tue Mar 17, 2020 9:09 am
    All within spec (slightly higher due to higher line voltage). All DC voltages from the manual are spec'd around the output tubes though. Would be interesting to know expected anode and cathode voltages on triode part of the tube, but they do look normal.
    Post by peterh Tue Mar 17, 2020 9:31 am
    The expected DC around the cathodyne is depending on tube used and normally not
    critical.
    You could expect the plate(t) to be at app 300V and the cathode (t) at app 100V,
    Penthode cathode is expected to be at 1V
    If plate ( triode) pin1 is still unsymmetrical it could indicate a problem with teh corresponding 6550 tube ( grid current )
    ViperZ
    ViperZ
    Post by ViperZ Tue Mar 17, 2020 10:52 am
    I tried different output tubes, it's not them.
    There is something really wrong on triode side. Looks like I have my triode completely open. My cathode voltage in both amps is 145V. Anode voltage on good amp is 300V, anode voltage on this amp is 175V. I'm losing half the voltage across 47K resistor connected to anode, so the vacuum tube must be fully open for some reason.
    Post by peterh Tue Mar 17, 2020 12:02 pm
    ViperZ wrote:I tried different output tubes, it's not them.
    Check plate(triode) resistor and the .25uF coupling cap
    ViperZ
    ViperZ
    Post by ViperZ Tue Mar 17, 2020 12:04 pm
    So far all resistors and traces belled out ok. Maybe it's the 12pF cap screwing everything up? I never changed 12 and 750pF caps on these amps.
    O.25 uF cap is almost new, it doesn't seem to be shorting out or open.
    Post by peterh Tue Mar 17, 2020 12:29 pm
    ViperZ wrote:So far all resistors and traces belled out ok. Maybe it's the 12pF cap screwing everything up? I never changed 12 and 750pF caps on these amps.
    There is a reason the plate(triode) is lower. Disconnect the cap and test he voltage again
    Measure the plate(triode) resistor, it should be 47k and close matched with the cathode(triod) resistor.
    You can also check the eyelet 5, it's not mentioned in the manual but it should have app 440Volt
    The 12pF has nothing to do with the plate(triode).
    ViperZ
    ViperZ
    Post by ViperZ Tue Mar 17, 2020 12:57 pm
    I do have correct voltage on pin 5, and 47k resistors check out fine, one is 52k in circuit, the other around 48k.
    Post by peterh Tue Mar 17, 2020 1:13 pm
    ViperZ wrote:I do have correct voltage on pin 5, and 47k resistors check out fine, one is 52k in circuit, the other around 48k.
    Change them. The are supposed to be exact matches ! But first, disconnect the 0.25uF and
    measure again.
    ViperZ
    ViperZ
    Post by ViperZ Tue Mar 17, 2020 1:28 pm
    Eyelet 5 has 325v on it. If I lift 0.25uF cap, that voltage goes up to 465v. No change to pin 1 problem.
    Also no change if I lift or swap 12pF capacitor.
    Post by peterh Tue Mar 17, 2020 1:35 pm
    ViperZ wrote:Eyelet 5 has 325v on it. If I lift 0.25uF cap, that voltage goes up to 465v. No change to pin 1 problem.
    Did you lift the coupling 0.25uF cap ?
    What cap did you lift ?
    Lifting a working cap ( disconnecting) should never give DC changes. That cap might be leaking.
    The 12pF cap HAS NO RELATION to the problem and besides it's orignal and good quality.
    Don't mess with it!
    Was the 47k resistor unequal after lifting the 0.25uF cap ? Then replace them with good matched ones please!
    ViperZ
    ViperZ
    Post by ViperZ Tue Mar 17, 2020 2:12 pm
    I replaced both 0.25 coupling caps, both 47k resistors and tube socket. No change. I'm out of ideas ....
    Post by peterh Tue Mar 17, 2020 3:01 pm
    ViperZ wrote:I replaced both 0.25 coupling caps, both 47k resistors and tube socket. No change. I'm out of ideas ....
    Are the two resistors equal when you ohm then in place and power off ?
    plate(t) to eyelet 5 and cathode(t) to eyelet 11 ( ground) ?
    If they are equal continue with ( with power on ) measure DC voltages
    - Plate(t) vs ground
    - cathode(t) vs ground
    -grid ( pin5) on 6550 relative ground, measure both
    Better be slow and methodical that making mistakes.
    ViperZ
    ViperZ
    Post by ViperZ Tue Mar 17, 2020 6:58 pm
    Both resistors are equal to eyelets that you mentioned. -59v on each pin 5 of kt88. Triode plate 2 to ground is 143v, cathode 3 to ground 144v, anode 1 to ground 174v
    ViperZ
    ViperZ
    Post by ViperZ Tue Mar 17, 2020 7:04 pm
    Weird problem with MK-III amplifier Img_2017
    Weird problem with MK-III amplifier Img_2016
    Compare pin 1 to pin 3 output
    Post by peterh Wed Mar 18, 2020 2:20 am
    ViperZ wrote:Both resistors are equal to eyelets that you mentioned. -59v on each pin 5 of kt88. Triode plate 2 to ground is 143v, cathode 3 to ground 144v, anode 1 to ground 174v
    You make me confused. What are the above numbers ( 1 2 3 ) ? Are you telling us that
    the 6an8 connections 1 2 and 3 ( 1=plate 2=grid 3=cathode , all referring to the triode part) ?
    Where are your scope readings taken ?
    Post by peterh Wed Mar 18, 2020 2:24 am
    Don't mess with it!
    Lifting a 0.25uF cap resulted in a huge DC change !
    Exactly which cap was this ? And what is the voltage in the 6an8 triode plate ( pin 1 ) when this cap
    is lifted ?
    ViperZ
    ViperZ
    Post by ViperZ Wed Mar 18, 2020 10:28 am
    1-2-3 are 6AN8 pins as marked on MK-III manual, all refer to triode part of the tube. 2 is input/grid, 1 is anode on the top, 3 is cathode on the bottom. Scope readings were taken relative to ground - good reading is on pin 3 cathode, bad reading is on pin 1 anode.
    The 0.25uF cap was the one connected on the cathode side to 6AN8 pin 3. I changed both 0.25 caps after that on the board, even though they were almost new, with no change. Lifting that cap did not change the problem on pin 1.
    Post by peterh Wed Mar 18, 2020 10:47 am
    ViperZ wrote:1-2-3 are 6AN8 pins as marked on MK-III manual, all refer to triode part of the tube. 2 is input/grid, 1 is anode on the top, 3 is cathode on the bottom. Scope readings were taken relative to ground - good reading is on pin 3 cathode, bad reading is on pin 1 anode.
    Which cap resulted in DC changes :
    "Eyelet 5 has 325v on it. If I lift 0.25uF cap, that voltage goes up to 465v. "
    This is strange and should be examined. Which cap was lifted when this happened ?
    As for the readings on the triode plate, the voltage indicated that something is
    either loadng down the plate OR
    the voltage on the other end av 47k resistor is too low
    What is the voltatge on eyelet 5 on the two amps ?
    ViperZ
    ViperZ
    Post by ViperZ Wed Mar 18, 2020 1:22 pm
    The 0.25uF cap connected to pin 3. I think it is strange too, maybe it's because the loading got removed off the tube, so it just shut off. I have not measured the voltage on eyelet 5 of a good amp. On this amp, with all parts installed, it is 325V on this amp.
    ViperZ
    ViperZ
    Post by ViperZ Thu Mar 19, 2020 3:45 pm
    Peterh, I just wanted to thank you for being patient and very helpful.
    I started troubleshooting outside the board and found the cause. It sucks to admit, but wires coming off stacked capacitor to eyelets 5 and 6 were swapped. They must have been swapped even before I rebuilt these amps, as I was replacing like for like everything.. still embarrassing. But the amp works great now.
    I will install my new 5AR4 rectifiers later today instead of 5U4s and rebias them.
    Post by peterh Thu Mar 19, 2020 4:38 pm
    ViperZ wrote:Peterh, I just wanted to thank you for being patient and very helpful.
    Glad to hear. Now you are in business again, one learns from experience !
      Current date/time is Fri Apr 26, 2024 5:56 pm
