    VTA70 PCB - What Happens if I Change C1 & C2 from 0.1 to 0.22uf?
    knotscott
    knotscott
    VTA70 PCB - What Happens if I Change C1 & C2 from 0.1 to 0.22uf? Empty VTA70 PCB - What Happens if I Change C1 & C2 from 0.1 to 0.22uf?
    Post by knotscott Wed Jun 03, 2020 6:42 pm
    The title contains the question - How much effect on sound and reliability does changing C1 & C2 from 0.1uf  to 0.22uf have?
    Why, you ask?   I just happen to have a few really good 0.22uf caps that I'd like to use if possible (same ones I used for the coupling caps).  Not sure I have enough to run them in series to get closer the value (I have 2 Dyna-VTA 70s), plus they're already fairly large for the space, and I don't want to butcher it by forcing 4 of these in there.
    As always, TIA!  (still loving the amps!)
    VTA70 PCB - What Happens if I Change C1 & C2 from 0.1 to 0.22uf? Empty Re: VTA70 PCB - What Happens if I Change C1 & C2 from 0.1 to 0.22uf?
    Post by Roy Mottram Wed Jun 03, 2020 8:37 pm
    should make no difference, it won't help, but shouldn't hurt
    knotscott
    knotscott
    Post by knotscott Wed Jun 03, 2020 8:38 pm
    tubes4hifi wrote:should make no difference, it won't help, but shouldn't hurt
    Thank you. Not planning on doing it any time soon, but perhaps someday I'll give it a try.
      Current date/time is Sat Apr 27, 2024 10:44 am
