    Bacon/static noise in the left channel of my PAS
    stevethemaestro
    Bacon/static noise in the left channel of my PAS Empty Bacon/static noise in the left channel of my PAS
    Post by stevethemaestro Sat Jul 04, 2020 3:45 pm
    I am having a problem identifying a noise that appeared suddenly in the left channel of my PAS3. There is a constant low level noise similar to bacon frying, accompanied by occasional louder pops and static noises. This noise appears only in the left channel, is present on all inputs and does not vary with the volume setting. It is similar in character to the sound of a failing tube, but when the tubes are swapped it remains in the left channel.
    I made a preliminary effort to find, perhaps, a loose connection by wiggling the tubes in their sockets. No change in the noise. The problem is with the high level board components somewhere after the volume control since the noise doesn't vary with the volume setting. It seems as if a part might be failing; any suggestions where to check first?
    Thanks!
    Bacon/static noise in the left channel of my PAS Empty Re: Bacon/static noise in the left channel of my PAS
    Post by peterh Sat Jul 04, 2020 5:24 pm
    stevethemaestro wrote:I am having a problem identifying a noise that appeared suddenly in the left channel of my PAS3.  There is a constant low level noise similar to bacon frying, accompanied by occasional louder pops and static noises.  This noise appears only in the left channel, is present on all inputs and does not vary with the volume setting.   It is similar in character to the sound of a failing tube, but when the tubes are swapped it remains in the left channel.
    Thanks!
    I would start replacing the plate resistors on the line board. One is 470k and
    the other 100k. 1/2w should do fine here
    470k has 180volt, 0.07w,
    100k 155Volt 0.24w
    MechEngVic
    MechEngVic
    Post by MechEngVic Thu Jul 16, 2020 2:40 am
    Any progress?
    stevethemaestro likes this post
    stevethemaestro
    Post by stevethemaestro Thu Jul 16, 2020 4:08 pm
    Yes, sorry!  Replacing the plate resistors solved the problem.  Thanks!
    MechEngVic
    MechEngVic
    Post by MechEngVic Thu Jul 16, 2020 4:16 pm
    stevethemaestro wrote:Yes, sorry!  Replacing the plate resistors solved the problem.  Thanks!
    Peterh knows his stuff, he's helped me several times.
    Dale Stevens
    Post by Dale Stevens Thu Jul 16, 2020 4:31 pm
    There we go, Peterh. Dale
      Current date/time is Thu May 02, 2024 3:08 pm
