    Newbee- Lots of Dynaco Questions
    LBK
    Newbee- Lots of Dynaco Questions Empty Newbee- Lots of Dynaco Questions
    Post by LBK Wed Sep 09, 2020 4:16 pm
    Your forum is great !!
    I have had Dynaco equipment since the 70's and have some of my dad's from the 60's.
    First project - ST-70- need recommendations on best instructional video etc to fire this one up. It has been idle for around 30 years. I am getting a Variac so it can be woken up gently. I am sure there must be some component testing I can do before giving it any power. I remember the old days of tube testers in electronics stores, does anyone offer that service or can you do most of that with a multimeter?
    My goal is to get the ST-70 running nicely as "stock" and may at some point look at upgrades.
    Good sources for parts?
    If anyone has suggestions on a forum for Dynaco transistor equipment I'd appreciate that as well. I have a Stereo 120 and PAT-4 that are still kits. A Stereo 410 that was assembled and tweaked by Audio by Zimet, I haven't started this up for about 10 years, again don't want to just plug it in.
    Looking forward to the projects and appreciate any helpful guidance.
    Many Thanks!!
    Newbee- Lots of Dynaco Questions Empty Re: Newbee- Lots of Dynaco Questions
    Post by Guest Wed Sep 09, 2020 6:31 pm
    Post by Bob Latino Wed Sep 09, 2020 7:03 pm
    We don't really discuss Dynaco solid state gear on this forum but if you have Dynaco solid state gear and need some help, check out the link below.
    Updatemydynaco.com
    LBK likes this post
    LBK
    Post by LBK Wed Sep 09, 2020 7:12 pm
    Thanks Bob. I thought I'd need another resource, I'll check it out.
    Post by peterh Thu Sep 10, 2020 2:38 am
    LBK wrote:Your forum is great !!
    Many Thanks!!
    As the st-70 has been off grid for 10 or more year, using a variac and
    watching the B+ is a good idea. It does however has a tube rectifier so the
    voltage will come suddenly. The idea is to charge the cap(s) to 100volt, wait,
    then 150Volt , wait, up to 400 during an hour. If the cap get warm or makes noices
    it should be replaced :
    https://www.dynakitparts.com/shop/multi-section-capacitor-1/
    Or , you could replace the can cap, and renew the bias components :
    https://www.dynakitparts.com/shop/st-70-bias-circuit-kit/
    instead of a varic ( if these are replaced there should be no probems powering on)
    LBK likes this post
      Current date/time is Wed May 01, 2024 8:18 pm
