I've looked at the wiring diagrams for the speaker terminals for the VTA70 upgrade, and as I'm about to undertake the installation
I'm a bit confused as to what to do with the unused wires and specifically where to attach the wire that goes to the NFB eyelet on the new PCB.
I intend to use one of the 3 binding post kits, with a common and 2 hot binding posts.
I intend to only connect taps that go to the 4 & 8 ohm taps - the brown and orange wires, and the common tap - black wire, and roll up the 16 ohm yellow wire so it does not accidentally contact the chassis.
Does the wire that goes to the NFB eyelet now go to one of the speaker taps in use?
Thanks in advance for your comments!
