    Where can I find the bias testing post mount thing?
    smoorenc
    Where can I find the bias testing post mount thing? Empty Where can I find the bias testing post mount thing?
    Post by smoorenc Wed Nov 04, 2020 11:14 am
    Hi All,
    I have searched and like talking to "Alexa", you have to phrase it correctly. I am sure I am calling the item the wrong name. I want to put digital volt display where the bias checking sockets are in the front of my ST-120. Then like I have seen others and also it looks like on the M-125 having bias meter testing posts mounted up top or in front. I don't know which ones to get. Can someone please point me in the right direction?
    Thanks Scott
    Hops likes this post
    Hops
    Where can I find the bias testing post mount thing? Empty Re: Where can I find the bias testing post mount thing?
    Post by Hops Tue Nov 10, 2020 9:10 pm
    Great Idea!. If you get a source for meters that fit the holes in the front of the St-120, and some alternative bias test points, I would like this also. Would be nice to be able to look over and just see the bias.
    smoorenc
    Post by smoorenc Tue Nov 10, 2020 9:32 pm
    I ordered these: https://smile.amazon.com/dp/B07VD2Z8W7/ref=cm_sw_em_r_mt_dp_U5ZQFbB1S36DS?_encoding=UTF8&psc=1
    Hxchen 2mm Female Extended Bind Post Alloy Socket Plug Panel Terminal Banana Jack Connector Black and Red - (10 Pcs)
    It looks like they will work. I will let you know how it works out, but they feel nice and heavy compared to the all plastic ones.
    Where can I find the bias testing post mount thing? 41oyfhyQGnL._AC_SL1001_
    Post by Roy Mottram Fri Nov 13, 2020 12:20 pm
    I've seen people buy mini DVMs and mount in those holes, or these simple test points . . .
    https://www.ebay.com/itm/DYNACO-Test-Jack-Boards-ST70-MKIII-MKIV-Bias-set/372632974031?
    aguaazul
    aguaazul
    Post by aguaazul Mon Nov 16, 2020 1:05 am
    Back in the day, Roy had these:
    My completed VTA - ST-70 photo album
      Current date/time is Fri May 10, 2024 2:48 am
