    Pic for Discussion entitled, "St-70, Left Channel, 60 Hz Hum"
    DynacoGuy
    Pic for Discussion entitled, "St-70, Left Channel, 60 Hz Hum"  Empty Pic for Discussion entitled, "St-70, Left Channel, 60 Hz Hum"
    Post by DynacoGuy Thu Nov 26, 2020 4:29 pm
    [url=Image hosted by servimg.com]Image hosted by servimg.com[/url]
    DynacoGuy
    Pic for Discussion entitled, "St-70, Left Channel, 60 Hz Hum"  Empty Please delete this blank post.
    Post by DynacoGuy Fri Nov 27, 2020 6:43 pm
    Blank
    DynacoGuy
    Pic for Discussion entitled, "St-70, Left Channel, 60 Hz Hum"  Empty Re: Pic for Discussion entitled, "St-70, Left Channel, 60 Hz Hum"
    Post by DynacoGuy Fri Nov 27, 2020 6:48 pm
    Pic for Discussion entitled, "St-70, Left Channel, 60 Hz Hum"  St70_c11
    I put callouts on the pic.
    A couple of things I could adjust,
    but not sure it would make a difference.
    The center taps, power xfmr and
    the Heat CT GNDs could be
    Removed form the ground buss,
    tied together and I'd add a wire to
    Locate them on Xfmr & 3rd prong GND lug.
    In another thread somewhere, can't recall,
    There should be continuity only on pin 2 to pin 2
    and only on pin 7 to pin 7 on each pair of power tubes.
    Is that correct?
    In this amp pin 2 and pin 7 have continuity throughout
    the amp on either side and in board.
    Any ideas?
    DynacoGuy
    Post by DynacoGuy Fri Nov 27, 2020 7:01 pm
    peterh wrote:What a nightmare !
    A few observations : Shorting inputs should never increase any hum. This seems to indicate a
    groundloop somewhere
    Removing the 7199 tubes : if hum remains will localize the area to the EL34 / bias / B+
    ( unbalanced powertubes might cause hum )
    How/where is the SDS board connected to ground ? That could be your source, and a source that
    will disappear if you rebuild with a cancap ( restoring the original config)
    As for diagnosing, a scope should be able to find and measure the hum, just turn sensitivity up.
    Having a value of the hum will make it much easier then to resort to listen with the amp
    moved from the workbench.
    I followed the Van Alstine protocol,
    Open inputs.
    left right swap:
    power tubes, hum stayed in left channel.
    7199 swap, hum stayed in left channel.
    Full tube complement with shorting plugs installed:
    Increased hum and Hum is now in both channels.
    Pulled 7199s, no hum.
    I have not added any additional caps other
    than the 8 in the power supply.
    The original multisection was disconnected and
    attached loosely with one glob of solder on a twistlock.
    When I tried to find the hum with the scope I couldn't find it.
    Unless I had brain fart and didn't recognize it.
    I couldn't hear it on my bench speakers...nothing.
    I went back and placed it into the system, then
    with extension chord plugged it into two different
    home power nodes...no difference. Hum remains.
    DynacoGuy
    Post by DynacoGuy Fri Dec 11, 2020 4:35 pm
    Look at the common output!
    There was no reference to ground on either,
    so I ran a ground wire from each common output
    to the ground buss in the amps center; the same
    location used by Dynaco.
    DG
      Current date/time is Sat Apr 27, 2024 3:26 pm
