    Another ST-120 build
    bobgroger
    Another ST-120 build Empty Another ST-120 build
    Post by bobgroger Sun Feb 21, 2021 4:10 pm
    Testing was on hold while I waited for a rectifier, but I remembered there was one in my Scott 299. Fired it up without the outputs first to verify there was audio out of the preamp. Hmm, no left channel. After a bit of troubleshooting I found I had forgotten to solder the center pin of the RCA jack. Then hooked up a dummy load, put the outputs in 1 channel at a time and biased, rebiased with all tubes and glorious music came out. I deviated from the design a bit, I drilled a couple holes and put the second choke where it should be. I wired it in Ultralinear only, and used one of the toggle switches as a standby switch. Note of warning: No matter how careful you are you WILL scratch up the chassis. I covered it entirely in masking tape, only uncovering as needed. Every screwdriver slip makes a nasty gouge. GE 6829 center tube, RCA 12AU7 phase splitters, EH KT88 outputs, RCA\Mullard GZ34.
    Another ST-120 build St120-10
    Another ST-120 build St120-11
    petrnyc likes this post
    Another ST-120 build Empty Re: Another ST-120 build
    Post by Dave_in_Va Sun Feb 21, 2021 5:33 pm
    Neat wiring! Congrats.
    Nice rectifier.
    Rbertalotto
    Post by Rbertalotto Tue Mar 02, 2021 8:31 am
    Can you show what you actually did here?
    Nice build BTW!
    edman44
    Post by edman44 Wed Jun 23, 2021 1:08 pm
    Nice Job, I hope when I build mine it comes out as nice as yours.
    Big Hat
    Big Hat
    Post by Big Hat Mon Jun 28, 2021 7:14 am
    Ignorant n00b question: Why is the left-hand choke generally cocked a a 10 - 30° angle and with only one mounting bolt?
    Outstanding build, bobgroger! Very pretty.
    Rbertalotto
    Post by Rbertalotto Mon Jun 28, 2021 7:31 am
    Lots of builders reorient this Xformer to be one with Fengsway......The single hole mounting is just a design decision for easy assembly.
    Big Hat
    Big Hat
    Post by Big Hat Mon Jun 28, 2021 7:45 am
    Thanks! I'm all over Feng shui, although if you saw my man cave/workshop you'd never guess it.
    Rbertalotto
    Post by Rbertalotto Mon Jun 28, 2021 8:01 am
    Laughing
      Current date/time is Sun Apr 28, 2024 11:29 am
