+4
Chad Spackman
Hops
grosen
8 posters
    ST120 click/flash in one tube
    grosen
    ST120 click/flash in one tube Empty ST120 click/flash in one tube
    Post by grosen Sun Mar 21, 2021 9:22 am
    Hi all,
    My ST120 has been trouble free since I built it, but just now I had a click and a flash in one tube (KT120), and now that socket won't bias.  (I get a reading of 20V or so.)  The problem doesn't follow the tube.  Can someone give me a clue about what to check first?
    Gideon
    grosen
    ST120 click/flash in one tube Empty Re: ST120 click/flash in one tube
    Post by grosen Sun Mar 21, 2021 11:43 am
    I just flipped it over and checked the obvious thing: the 10 ohm resistor to ground from pin 8 on that socket is open.  So I assume that's either the problem or a symptom of the problem.  Should I just replace it and see what happens?  Any idea what would cause the resistor to fail?   Thanks in advance!
    Gideon
    Post by Bob Latino Sun Mar 21, 2021 11:47 am
    grosen wrote:Hi all,
    Gideon
    Hi Gideon,
    The 10 ohm 2 watt resistor on the tube socket that goes from pin # 8 to chassis ground is probably bad and does not measure 10 ohms anymore. Check to see if it measures 10 ohms. If it does not, you can get a few very cheaply at the Ebay link below.
    https://www.ebay.com/itm/2W-2-Watt-1-Tolerance-Metal-Film-Resistor-5-Pieces-USA-SELLER/183421853100
    Be sure to select 10 ohms from the drop down menu ..
    NOTE - when that 10 ohm resistor is damaged, it usually indicates that the tube that was in that socket and gave a "flash" has an issue. I would replace that tube.
    Tom Pickett likes this post
    Post by Bob Latino Sun Mar 21, 2021 11:50 am
    The tube that was in that socket at the time of the flash is most likely bad. It may bias OK after you replace the resistor but I would not trust the tube that was in there anymore.
    grosen
    Post by grosen Sun Mar 21, 2021 11:51 am
    Thanks, Bob. I'll replace the resistor and the tube. — Gideon
    Hops
    Post by Hops Sun Mar 21, 2021 1:35 pm
    While I think replacing the resistor and the tube is necessary, I would also re-tension the pins in the bad socket and clean them with deoxit or other good contact cleaner. I would also check the incoming voltage of the power ( I forget what Bob recommends, but 119 V or less should be good, and make sure the bias is at Bob's recommendation or a little less - I think the target is 0.5 Volt. Tubes are expensive, and you want to rule out anything that can make tubes more likely to fail.
    Chad Spackman
    Post by Chad Spackman Fri Jan 14, 2022 11:54 am
    Just had one of my 10 ohms go in a VTA-120. Of note: pins 1 (tube frame) & 8 (cathode) of the KT88 are tied together. With cathode not tied down by 10 ohm, it and the frame wonder up to B+. There is no appreciable source of current there until it drops to under about 50v or a bit less. So it's not gonna hurt too much
    nmchiefsfan
    Post by nmchiefsfan Fri Jan 14, 2022 5:12 pm
    I took measurements on some KT-88s and KT-120s that I have on the shelf and NONE of them are connected from pin 1 to pin 8. Some are connected from pin 1 to the base of the tube though. The KT-88s are Golden Dragon and Sov Tec. The KT-120 is Tung Sol. Are all of your tubes like this? Maybe you have a shorted tube.
    Chad Spackman
    Post by Chad Spackman Fri Jan 14, 2022 6:09 pm
    This is vta-120 specific.  1 and 8 are connected within the amp, by design
    Post by Bob Latino Fri Jan 14, 2022 8:32 pm
    I consulted with Roy Mottram just to be sure before answering here ... On an EL34 (and also on 6L6GC) pin 1 is tied to the screen grid (pentode) and should NOT be left unconnected. These tubes are almost always connected to cathode on 90% of tube amps out there. On all KT88, 6550 and KT120's pin #1 has no internal connection to any other pin although some brands of these three tubes do connect pin 1 to the metal base of the tube. It is better to connect pin #1 to pin #8 so that both are near 0 volts rather than having them floating above chassis ground. If you connect pin 1 and 8 together, you can then use virtually any type of octal output tube in a Dynaco or VTA amp.
    Chad Spackman
    Post by Chad Spackman Fri Jan 14, 2022 11:25 pm
    Thanks Bob. Just to be clear, I was in no way questioning the wisdom of connecting pins 1 and 8 and your detail here of various tube types makes perfect sense. I just happened to be using the frames to look at the bias as I’d not yet put in the standard test points. And with an open 10 ohm I noted the high voltage, which of course also makes sense
    Chad Spackman
    Post by Chad Spackman Sun Jan 16, 2022 9:07 am
    A question related to the flashover. In my case it was a 6550. New tubes. Installed, biased, and idled for about 30 minutes. Started listening and while turning up the volume, one tube flashed. My question: are 6550s more susceptible flashover this than kt88s? With a static plate voltage of mid 500 volts, there is going to be a positive voltage during AC swing on the non-driving tube to well over 600v, which appears to be the limit on 6550s.
    Post by peterh Sun Jan 16, 2022 2:51 pm
    Chad Spackman wrote:A question related to the flashover. In my case it was a 6550. New tubes. Installed, biased, and idled for about 30 minutes. Started listening and while turning up the volume, one tube flashed. My question: are 6550s more susceptible flashover this than kt88s? With a static plate voltage of mid 500 volts, there is going to be a positive voltage during AC swing on the non-driving tube to well over 600v, which appears to be the limit on 6550s.
    6550 should not flashover. Ask for warranty replacement a tube with same matching parameters .
    Post by corndog71 Sun Jan 16, 2022 3:04 pm
    This can happen to any tube. Most tubes are not made with white gloves. Debris happens.
    Post by peterh Sun Jan 16, 2022 5:00 pm
    corndog71 wrote:This can happen to any tube.  Most tubes are not made with white gloves.  Debris happens.
    Might be. But tube is junk and should be scrapped.
    Jim McShane
    Post by Jim McShane Thu Jan 20, 2022 3:33 pm
    Bob Latino wrote:I consulted with Roy Mottram just to be sure before answering here ... On an EL34 (and also on 6L6GC) pin 1 is tied to the screen grid (pentode) and should NOT be left unconnected. These tubes are almost always connected to cathode on 90% of tube amps out there. On all KT88, 6550 and KT120's pin #1 has no internal connection to any other pin although some brands of these three tubes do connect pin 1 to the metal base of the tube. It is better to connect pin #1 to pin #8 so that both are near 0 volts rather than having them floating above chassis ground. If you connect pin 1 and 8 together, you can then use virtually any type of octal output tube in a Dynaco or VTA amp.
    Bob,
    I think you meant pin 1 is connected to the SUPPRESSOR grid, not the screen grid.
    Also, you can use an ohmmeter to check if pin 1 is connected to the metal base - just connect the meter from pin 1 to the base and see if you have continuity.
    Post by Bob Latino Thu Jan 20, 2022 4:18 pm
    Bob,
    Hi Jim,
    Yes - you are correct .. Pin 1 is connected to the suppressor grid. I must have read incorrectly what Roy Emailed me ..
      Current date/time is Sat Apr 27, 2024 5:51 pm
