    SP14 Build question - Ground from volume
    IntarsiaGuy
    SP14 Build question - Ground from volume Empty SP14 Build question - Ground from volume
    Post by IntarsiaGuy Mon May 31, 2021 8:35 am
    The ground from the master volume (also grounded to the other 2 attenuators) is supposed to go to the "signal input ground" on the PCB. I am not sure where I am supposed to connect it. Any of the edge grounds on the far left side? Seems that would only ground one channel. Would appreciate some guidance. Thanks.
    Pablo
    SP14 Build question - Ground from volume Empty Re: SP14 Build question - Ground from volume
    Post by Pablo Mon May 31, 2021 7:26 pm
    It's been a few years since I assembled my SP14, but as I recall the two ground terminals on the master volume control get a jumper run between them, and the nearest edge ground point on the PCB gets connected to the jumpered terminal on the volume control.
    IntarsiaGuy
    Post by IntarsiaGuy Mon May 31, 2021 8:14 pm
    Thanks for the response, Pablo.
      Current date/time is Sun Apr 28, 2024 1:30 am
