by ttocs Sat Sep 18, 2021 4:25 pm
"Well the squirrels are back again". (sorry, tv commercial)
Well, the 12BH7AEH tubes arrived early. So I've been going through some measurements to get a new baseline for the Krell solid state, and the M-125 with original supplied 5963 tubes.
I'm not using any Processor EQ or Room Correction, just straight up whatever it happens to output.
In running through some sweeps I decided to tweak the settings on the speaker to tilt the bass/mid-bass down a touch which on my speakers is -1dB Bass Control, and -2dB Mid Bass Switch. This helped to level the playing field because without these adjustments the bass is much more prominent, and by more than the settings would imply. A -1dB adjustment actually accounts for a -3dB difference for in-room measurement.
So all I'm working with right now is just the new 12BH7 tube, the resistors have not arrived. I inserted the 12BH7 into the rear tube socket, am I correct in using it in this position? I can't find my assembly manual since I cleaned up the basement, it's in a new bin somewhere. The bias is slightly higher with the 12BH7 by 0.035V, so I adjusted down to 1V.
Using the 12BH7 the amp has a bit more output by just under 1dB above 500Hz, and the falloff above 5500Hz has a different slope and hangs on better to 10kHz, but both tubes are exactly the same at 10-11kHz. While I don't consider this to be great, it's not remarkable, it's also not bad, it helps a little.
So my work-in-progress judgement at the moment is that there is more output where I'm looking for it.
Listening will tell the tale.
edit: Initial measurements while using a brand new tube notwithstanding, there's some good stuff, and some not so good. So I'll give the new 12BH7's some time. Too early to judge SQ.
edit2: It only took a few hours to substantially reduce the sibilance, selective glare, and unevenness. The sound is quite good now after about 8 hours on the 12BH7's, but everything in the midrange is a bit too forward. I didn't need more mids. But there is a touch more "sparkle" in the highs, which is what I want.
The resistors arrive early in the week, so R28 can be swapped out. I don't know how this will affect the sound, but I'll find out.
