    A-430 or A-431 winding
    fobya71
    A-430 or A-431  winding Empty A-430 or A-431 winding
    Post by fobya71 Wed Dec 01, 2021 7:23 am
    I saw it was posted time ago the winding sequence of the A-470 transformer.
    Somebody know about the winding of A430/ A431 output transformers? Or are them still a secret?
    A-430 or A-431  winding Empty A430 or A431 Windings
    Post by stewdan Wed Dec 01, 2021 10:07 am
    Hi --- is this what you are looking for??
    http://www.tubebooks.org/file_downloads/dynaco_transformers.pdf
    Check the A43X diagrams.
    Stew
    fobya71
    A-430 or A-431  winding Empty Re: A-430 or A-431 winding
    Post by fobya71 Wed Dec 01, 2021 10:33 am
    stewdan wrote:Hi --- is this what you are looking for??
    Stew
    No, I know about external connections.
    I mean the sequence of turns into the transformer coils.
    F.
    A-430 or A-431  winding Empty Dynaco A430/A431
    Post by stewdan Wed Dec 01, 2021 3:27 pm
    Hi --- Take a look at these links, I think the 1st one is what you are looking for.
    The A470 OPT Winding Diagram ..................
    http://www.diytube.com/phpBB2/viewtopic.php?t=3694&sid=057d98e9066c0d0915878e91e02602e5
    Dynaco A470 Output Transformer Measurements
    https://www.audioasylum.com/cgi/vt.mpl?f=amp&m=196142
    Stew
    fobya71
    Post by fobya71 Thu Dec 02, 2021 5:02 am
    stewdan wrote:Hi --- Take a look at these links, I think the 1st one is what you are looking for.
    Stew
    Ok, but all this info are for the A-470 transformer which was/is used on ST70. I need info about the A-430/A-431, which was /is used on the Dynaco MKII and MKIII monoblocs.
    Iguess the winding is more or less same.
    The input and output impedance is the same (4.3K input, 4-8-16 output), but the power is different, so I think that iron and wires has slghtly bigger dimensions than the one reported for the A-470.
    I needed for two reason: I have two transformer in theory compatible with Dynaco MKII, but I have some suspect they do not have same winding. Then, I would like to wind myself two clones just for fun, and also for use on my monoblocks Smile
    F.
    A-430 or A-431  winding Empty Dynaco Winding Info for A43x
    Post by stewdan Thu Dec 02, 2021 10:44 am
    Hi ---- I went to the diytube link
    and clicked on each of the Board Index < Amplifiers < ST70 and Mark III parts of the link but could NOT find Mark III or A43X OPT info that looks like the A470 info.
    I also checked at audioasylum, audiokarma and a few other tube sites, but came up empty.
    So, I am out of ideas.
    Good luck,
    Stew
      Current date/time is Sun Apr 28, 2024 12:49 am
