    ST120 VTA Driver board build.
    Gabriel
    ST120 VTA Driver board build. Empty ST120 VTA Driver board build.
    Post by Gabriel Thu Jan 27, 2022 11:07 am
    Hi
    I have a question about the driver board, in particular the resistors.
    R19-22 is a 27K 1watt.
    The resistors I received does not have the usual colour codes for resistors  and has the value 27 k printed on the case.
    Is it ok for me to use the above resistors?
    The image I attached is my driver board.ST120 VTA Driver board build. 83acb110
    Gabriel
    Blitzen
    Blitzen
    ST120 VTA Driver board build. Empty Re: ST120 VTA Driver board build.
    Post by Blitzen Thu Jan 27, 2022 11:41 am
    You are testing all the resistors before you put them in, right?
    alexbramford likes this post
    Gabriel
    Post by Gabriel Thu Jan 27, 2022 9:49 pm
    Yes. I used a multimeter to check all the resistors and confirm their values.
    There is only one resistor with this value 27k 1 watt so I assume this must be the resistor for R19-22.
    ST120 VTA Driver board build. B9a39610ST120 VTA Driver board build. B9a39610
    Blitzen wrote:You are testing all the resistors before you put them in, right?
    Post by Roy Mottram Thu Jan 27, 2022 9:56 pm
    yes of course this are fine high quality resistors, otherwise they would not have been supplied with the kit
    Gabriel
    Post by Gabriel Thu Jan 27, 2022 10:19 pm
    Hi
    My OCD is stopping me from making common sense decisions..sorry..
    I reviewed the photos on your website and noticed the boards don’t all have colour coded resistors, which kind of answered my question.
    Thank you for clarifying the situation.
    tubes4hifi wrote:yes of course this are fine high quality resistors, otherwise they would not have been supplied with the kit
      Current date/time is Wed May 08, 2024 5:08 pm
