    ST-70 Bias Drift
    justin_122
    justin_122
    ST-70 Bias Drift Empty ST-70 Bias Drift
    Post by justin_122 Fri Mar 18, 2022 11:03 pm
    Group,
    I have a question on bias voltage that I have always been curious about, but it has never bothered me enough to ask about it, until now. I have two ST-70s, both with VTA boards. One has 12AU7 tubes, and the other has the octal board (6SN7 tubes). Both exhibit a slight bias drift downward as they warm up. For example, if I turn an amp on and wait 5 minutes, then take a bias voltage reading, it will read .42VDC (which is where I set it). Then as the amp operates for say two hours the bias voltage will drift downwards to .40VDC, which is the target bias voltage for EL34 tubes. My dumb question is, is this normal or should I be looking for a problem? I thank you in advance for your input.
    Chuck
    ST-70 Bias Drift Empty Re: ST-70 Bias Drift
    Post by peterh Sat Mar 19, 2022 4:45 am
    justin_122 wrote:Group,
    Chuck
    It seems perfectly reasonable. Don't worry !
    Post by Roy Mottram Wed Mar 30, 2022 9:16 pm
    most amps I've seen the bias actually drifts up slightly when warm, which is why on a new amp you want to set the bias, then check it about half hour later.
    Then it should be fine for a couple weeks. Unless you home AC power drifts more than 1v per day. Mine is dead steady at 122-123vac all the time.
    And I run my amps with a variac set at 117vac
      Current date/time is Mon May 06, 2024 12:12 pm
