    VTA M-125 on 2 tubes
    ranges
    VTA M-125 on 2 tubes Empty VTA M-125 on 2 tubes
    Post by ranges Wed Mar 23, 2022 3:35 pm
    Hello
    I just wanted to ask what the bias should be set at for 2 KT-88s. Also what tube position is recommended for the tubes. I switched over from electro harmonix 12BH7 to Gold Lion, Kevin's Stash 12AU7s. Switched the unit on and lost a Webber and a KT88. Going to run two tubes per mono until 8 new KT88s make it in.
    Thanks in advance.
    rebellovw
    VTA M-125 on 2 tubes Empty Re: VTA M-125 on 2 tubes
    Post by rebellovw Wed Mar 23, 2022 3:39 pm
    It should be .500 V. Half of what you normally bias.
    Run in front position where it is cooler.
    ranges likes this post
    Tom
    Post by Tom Thu Mar 24, 2022 5:32 am
    I think I also read on here that Bob says you can cut them back from 0.5 to 0.45 with no sound quality loss, cooler and improves tube life. I run my M125s with just a pair of KT120 each. Going to try 0.45 next time I check bias.
    Tom
    Post by Tom Thu Mar 24, 2022 5:40 am
    LeGrace
    LeGrace
    Post by LeGrace Thu Mar 24, 2022 10:28 am
    I would not bias a KT120 that low, 6550 maybe. Seems to be a fad these days, how low can you go.
    Post by corndog71 Thu Mar 24, 2022 11:56 am
    There is nothing wrong with going lower. I run my KT120s at 0.40vdc each with no loss of performance. I recall an anecdote I read from a tube seller who spoke with an engineer from Sylvania back in the 80’s. The engineer recommended running power tubes at half their max dissipation and they’ll last longer.
    I know many people run them higher but I could never find a good reason to do so other than someone’s opinion that they may sound better. One thing that we do know is the higher the bias the shorter the life span.
      Current date/time is Sun Apr 28, 2024 9:05 am
