    MKIII Bias at 1.7v
    snip73
    MKIII Bias at 1.7v Empty MKIII Bias at 1.7v
    Post by snip73 Tue Apr 05, 2022 7:33 pm
    Greetings. It's been ten years since I restored my MKIII's, and they have not seen much use since. I ordered sand installed some banana type plugs and did away with the old screw terminal strips. After wiring them in, one amp biases to .50v and the other is up around 1.7v on both output tubes.
    The restore was done using "Roy's" boards; individual bias controls amongst other things. I'm not that experienced with these projects, and it's been some time since I did this as a hobby... so I am hoping someone can lend a hand. Thanks.
    MKIII Bias at 1.7v Empty Re: MKIII Bias at 1.7v
    Post by peterh Wed Apr 06, 2022 2:46 am
    snip73 wrote:Greetings. It's been ten years since I restored my MKIII's, and they have not seen much use since. I ordered sand installed some banana type plugs and did away with the old screw terminal strips. After wiring them in, one amp biases to .50v and the other is up around 1.7v on both output tubes.
    As this are no dynaco MkIII ,schematics should be posted to have any accurate advices.
    snip73 likes this post
    snip73
    Post by snip73 Wed Apr 06, 2022 6:38 am
    Post by peterh Wed Apr 06, 2022 7:32 am
    looking at the published schematics :
    measure the grid voltage ( bias) If it's normal ( compare with the other amp) then
    there could be a problem with the cathode resistors or the ground connection(s)
    snip73
    Post by snip73 Wed Apr 06, 2022 12:27 pm
    The cathode resistors all measure @ 10K, so I will look into the ground issue. Thank you.
    snip73
    Post by snip73 Wed Apr 13, 2022 10:35 am
    It was dirty potentiometers. Amateur mistake! Thank you for your help.
      Current date/time is Thu May 02, 2024 10:59 pm
