So I have my MKIII pair up and running; they sound good, not a lot of hum or hiss but one amp has a lot less volume than the other. I re-did these 10 or so years ago with the VTA boards so the 470K resistor is not present... I am not sure where to begin troubleshooting other than I did switch out the output and rectifier tubes with no changes noted.
Low Volume On One Amp of Pair (MKIII)
simpleton- Posts : 5
Just a thought, but have you tried swapping the inputs between amps to verify your source is good?
snip73- Posts : 16
I should have mentioned that I did do that as well. Thanks.
peterh- Posts : 1833
It makes me think that this is no Dynaco MkIII. If they are something elsesnip73 wrote:So I have my MKIII pair up and running; they sound good, not a lot of hum or hiss but one amp has a lot less volume than the other. I re-did these 10 or so years ago with the VTA boards so the 470K resistor is not present... I am not sure where to begin troubleshooting other than I did switch out the output and rectifier tubes with no changes noted.
and you want intelligent answers you should post correct schematics.
snip73- Posts : 16
Schematics here. No disrespect; I just assumed there might be a common "go to" point for troubleshooting that didn't require posting them:
https://ibb.co/6tBHbnR
https://ibb.co/x2Cr8Zc
mijohn- Posts : 119
Have you tried swapping tubes between the good and bad amps?
The amplification is basically set by the quote R7 / R5 , the resistors in the feedback chain.
This is provided that the amp works without dist and is able to pull full power, if it distorts and/or
cannot produce full power it might be one side of the phase inverter that has problems.
