I had posted on here how I was using Gold Lion KT88 tubes on an original ST70 with the VTA board and upgraded transformer installed. I also installed the "yellow sheet" mod on the rectifier transformer and the Triode Ultralinear switches. So after current world events I decided I needed a backup set of KT88s just in case my Gold Lions decided to die on me so I ordered a matched quad of Chinese PSvane KT88 tubes. I want to mention that the amp was dead silent and sounded wonderful prior to installing the PSvanes. When I put the PSvanes in the first time, I was starting to adjust the BIAS when lightning in a bottle happened on the rectifier and blew the fuse. So I turned the bias pots on the VTA board all the way down and tries again. Same thing, after the amp warmed up, lightning in a bottle on the rectifier and blown fuse.
After all this I now have a loud mechanical hum coming from the amp. I replaced the power transformer and the hum is still there. I have new output transformers that I purchased from ( https://www.laboratoriomusicale.net/en/output-transformer-dynaco-a470-for-st-70-4300-ct-4-8-ohm-replica-new ) (I am in the US but the site said:
"The primary is wound the same as the original A470, same number of turns, sections and wire size, using the same patented Dynaco winding method, and made on the same core size and material. Only improved insulation material used (thus making the transformer more resistant to abuse) and nice long (10 inch/ 25 cm minimum) high temperature insulated leads have been added."
and they were almost half the price of transformers here in the US).
I am hesitant to replace the original output transformers because they sounded so good prior to all of this. When I push down on the left output transformer, the hum gets quieter (not all the way gone by any stretch but quieter) This does not happen on the right transformer or the power transformer. I am also not getting any hum through the speakers only on the unit itself.
Could this be an output transformer? Is there a way to repair the original output transformer? If I were to replace the output transformer, should I replace both right and left? All caps are less than a year old.
Thank you!
Mark
Thank you!
Mark
