ST-70 what is a safe input VAC
raudio44- Posts : 48
- Post n°1
Hi everyone, could use some idea of what range input VAC (high and low) is acceptable for my ST-70. Looking at a bucking transformer on eBay that was noted in another post here. What should be the lowest VAC that would be, OK? Thanks, and appreciate any responses, R
TubesGlo- Posts : 6
Re: ST-70 what is a safe input VAC
My ST-70 is stock but completely overhauled with fresh components and is tube rectified. I built a bucking transformer plugged into a line conditioning surge protector. The transformer knocks voltage down to 117-119VAC. I have a CL90 inrush limiter after the fuse which knocks voltage down to 115- 117 on average. The very lowest I would want to see would be 110. It was recommended to me by Dave Gillespie to aim for 115.
raudio44 likes this post
My 70 is about the same, updated, but pretty much stock. Wouldn't think going down to 110 would be ok but am not a tech so I wouldn't know. Good to know and what I wanted to find out. Thanks for the reply and info, much appreciated.TubesGlo wrote:My ST-70 is stock but completely overhauled with fresh components and is tube rectified. I built a bucking transformer plugged into a line conditioning surge protector. The transformer knocks voltage down to 117-119VAC. I have a CL90 inrush limiter after the fuse which knocks voltage down to 115- 117 on average. The very lowest I would want to see would be 110. It was recommended to me by Dave Gillespie to aim for 115.
TubesGlo likes this post
Roy Mottram- Admin
any AC input between 110-120vac should be fine, I like to aim for 117vac and use a variac
Brap- Posts : 231
Safe Input VAC
Per Bob Latino, 117-118 using an inexpensive variac. I fluctuate wall VAC +/-8 at my plac and a variac works great. $65.00 well spent and can use it on the bench too.
- Post n°6
Well after spot checking my VAC (haven't done it that much and seems to come in at about 124.5) it was at 126VAC! that did it. Had been thinking about this for a long time and finally bought the one off eBay which has an outlet for a 3% and one for a 7% drop. More than I wanted to spend and not up for building one. For me, at least, seemed like the way to go. My main question is what is too low, but I think under 115VAC. Any thoughts? Thanks everyone, your input is much appreciated!
Brap- Posts : 231
- Post n°7
115VAC should be fine. I am able to adjust the output on my variac to dial it in depending on what the wall is giving me. Have a Furman in my rack of gear which provides a readout of the wall voltage. My VTA is plugged into the wall at a separate outlet and I placed the variac in series there. I read the Furman voltage, then adjust the variac to 118VAC for the VTA.
raudio44 and TubesGlo like this post
TubesGlo- Posts : 6
- Post n°8
Brap wrote:115VAC should be fine. I am able to adjust the output on my variac to dial it in depending on what the wall is giving me. Have a Furman in my rack of gear which provides a readout of the wall voltage. My VTA is plugged into the wall at a separate outlet and I placed the variac in series there. I read the Furman voltage, then adjust the variac to 118VAC for the VTA.
Good way to go. My Furman has 3 settings, wide , normal and narrow. Incoming is usually 122-124. I set to wide and my bucking transformer knocks it down to 117-119. I've measured after the CL-90 where it's brought down another 2 volts. With the stock PA060 I'm happy at 115-117.
Brap- Posts : 231
- Post n°9
Three settings -- havent seen that one. What model? I have the PL plus DMC. See my avatar and you may see it in the rack
TubesGlo- Posts : 6
- Post n°10
My mistake, I have the Furman Elite DMi in theater rack and a APC H15 on the 2ch gear which has the 3 voltage trim settings.
penguinpages- Posts : 29
- Post n°11
Interesting topic. Can someone add a bit more meat on the bone on this topic that is more electrically trained (vs youtube self trained like myself
I have Dynaco ST120 amp kit from this company. And my input voltage ranges were 126-128 and some days I saw 124 so ugly. So I put in variac and set voltate to 110 as that reflected the Dynaco Tube design "sweet spot" based on it being built back pre-120 switch (from 110v)
Question:
1) What is the pros / cons of setting lower or higher input voltage range (What is the best voltage to set the unit at and if I deviate up / down what is the effect)
2) What is the amp "input impedance"? . I have a set of Active Servo Subs which take of the bottom 1.5 octave of load from the amp, but posting about maybe moving from active (DSP) to passive filter may increase quality and so need to know this value https://www.youtube.com/watch?v=65eFr2rKy3M
Brap- Posts : 231
- Post n°12
Cant speak to the servo subs since I don't use one and if I did it would be active out of the pre-amp not connected to my VTA. According to Bob, 117-118VAC for a VTA ST-70 is preferred.
Bob Latino likes this post
