    Driver Tube Questions Stock ST-70
    raudio44
    Driver Tube Questions Stock ST-70 Empty Driver Tube Questions Stock ST-70
    Post by raudio44 Sat Dec 17, 2022 2:12 pm
    Running an updated, stock ST-70 with Sylvania 7199s, an NOS International Servicemaster made in Japan GZ34, and 'real' SED Winged C EL34s.
    Could someone tell me the symptoms of a bad driver tube? Not a tech and don't have a tube tester. Trying to determine what my problem is and with limited knowledge.
    Seems like my left channel is lower than the right. first changed preamps but that was not it. swapped output tubes to opposite channel. other steps also.
    this is just to eliminate a 7199 as a possibility. I have a couple things I still want to check. My apartment living room wall is not ideal for speaker placement which is a nagging thought I am hoping is not the issue after all.
    Some general thoughts would be appreciated. Happy holidays and New Year to all...     R
    Driver Tube Questions Stock ST-70 Empty Re: Driver Tube Questions Stock ST-70
    Post by peterh Sat Dec 17, 2022 2:46 pm
    raudio44 wrote:Running an updated, stock ST-70 with Sylvania 7199s, an NOS International Servicemaster made in Japan GZ34, and 'real' SED Winged C EL34s.
    Leave the amp to Your favorite amp technician, he will hook it up to a sinus generator
    and artificial load. He will tell you if anything is wrong and also suggest how to correct.
    Last edited by peterh on Sat Dec 17, 2022 2:46 pm; edited 1 time in total (Reason for editing : Spelling)
    Brap
    Brap
    Post by Brap Mon Dec 19, 2022 11:30 am
    Did you swap the 7199 tubes to see if the situation changed to the other channel?
    raudio44
    Post by raudio44 Mon Dec 19, 2022 12:47 pm
    Don't have a local tech. It was gone over / updated a few years ago by a reputable tech. Just determined the amp is fine, the problem turned out to be uh, me! rechecked a couple things and seems fine now. thinking it was a speaker binding post issue. thought i did that before but?? thank you for your reply. have a great new year.
    MechEngVic likes this post
    raudio44
    Post by raudio44 Mon Dec 19, 2022 12:52 pm
    Brap wrote:Did you swap the 7199 tubes to see if the situation changed to the other channel?
    That was going to be my next move; was looking to see what a bad driver tube would exhibit as a problem to watch for. I think I found the issue as you can see in my last post here. still would like to know about the driver tubes. Thank you for your reply, very much appreciated. Happy holidays and new year.
      Current date/time is Sun Apr 28, 2024 4:21 am
