    Power Tower
    CletusB
    CletusB
    Power Tower Empty Power Tower
    Post by CletusB Sat Jan 07, 2023 8:55 pm
    Well, today I "finished" building this power conditioning and distribution system for my stereo system, repurposing an old Mac Pro case donated by a friend.
    Here are the features:
    1. Main AC Latching Relay  (drops out and locks out on a power outage, manually reset)
    2. GFCI
    3. Z-Wave smart-switch (Alexa voice actuated power control)
    4. RFI filtering
    5. Servo Variac automatic mains voltage regulation (Input swing 85Vac to 170Vac, output front panel adjustable, maintains +/-1V of nominal setting)
    6. Digital AC raw mains display
    7. Digital regulated AC output display
    8. Linear 5V 3A regulated DC power supply (for Raspberry Pi/Allo Boss DAC)
    9. Sequenced power-up (2-stage) for the various stereo component groups
    10. AC voltage ramp up (soft start) for tube amp.
    11. Spike protection MOVs
    Works a peach, what I find superbly impressive is the glaring sonic difference upgrading from a 5V 2.5A switch-mode power supply to a linear 5V 3A regulated power supply for my Raspberry Pi3 / Allo Boss DAC / 2TB music server.
    These cases are really awesome when gutted and repurposed for projects.
    A little neatening up to do with some 3D printed bezels around the front outlets, and that should happen tomorrow. Right now I'm just sitting back with a fine Bourbon and enjoying the music.
    Power Tower Power_11
    aguaazul, Dave_in_Va, mijohn and Dale Stevens like this post
    dalemurray
    dalemurray
    Power Tower Empty Re: Power Tower
    Post by dalemurray Mon Jan 09, 2023 11:27 am
    No photos of the guts?
    I'm currently using a variac to adjust the power to my ST-120. I regularly get 124-127v at the outlet and the ST-120 does not lit it one bit.
    It would be nice to have something to make that adjustment without my involvement.
    CletusB
    CletusB
    Post by CletusB Mon Jan 09, 2023 11:35 am
    dalemurray wrote:No photos of the guts?
    The Servo Variac I'm using is this unit, it works very well. I replaced the internal trimpot with a panel mounted 10-turn 1K pot so I can easily set the output voltage, right at the front.
    Power Tower Stab112
    Power Tower Stab212
    Power Tower Stab312
    dalemurray
    dalemurray
    Post by dalemurray Mon Jan 09, 2023 11:44 am
    Thanks.
    It would be nice to have something I do not need to monitor to know I'm only delivering 120v to the ST-120.
    gktamps
    gktamps
    Post by gktamps Mon Jan 09, 2023 12:43 pm
    @CletusB:
    Nice job on your power conditioning/distributing system! Gut shots would be appreciated.
    The automatic voltage regulator is interesting, but it raises questions.
    1. How quickly does it adjust output voltage when there is a change in line voltage?
    2. What is the line voltage variation that causes it to auto-adjust (e.g. 1, 2, 5v)?
    3. Does it adjust output higher for low line voltage? What happens if there is a short duration brown-out - does it drop output voltage quickly enough to protect the load?
    4. I notice it has no AC chassis ground wire at the entrance to the chassis. Are you concerned about not having any grounds to your loads?
    Thanks!
    CletusB
    CletusB
    Post by CletusB Mon Jan 09, 2023 12:49 pm
    dalemurray wrote:Thanks.
    https://bkmiami.com/product/1000va-automatic-voltage-stabilizer/
    CletusB
    CletusB
    Post by CletusB Mon Jan 09, 2023 12:59 pm
    gktamps wrote:@CletusB:
    1.  How quickly does it adjust output voltage when there is a change in line voltage?  It's slow maybe 1.5sec, but fast enough to keep up with our variation due to loads on the grid from nearby factories.
    2.  What is the line voltage variation that causes it to auto-adjust (e.g. 1, 2, 5v)? - ~2v
    3.  Does it adjust output higher for low line voltage? -  Yes  What happens if there is a short duration brown-out - does it drop output voltage quickly enough to protect the load? - My latched relay will drop out clean
    4.  I notice it has no AC chassis ground wire at the entrance to the chassis. Are you concerned about not having any grounds to your loads? I added a ground, GFCI, EMI Filter Etc.
    Thanks!
    This is where it's at:
    Power Tower Power_12
    Power Tower Power_13
    Power Tower Power_14
    Seamus
    Seamus
    Post by Seamus Mon Jan 09, 2023 2:37 pm
    Even today many power transformers are spec'd @ 115v.
    Line voltage regulation is supposed to be ±5% in the US. 105% of 115 is 121.
    A bucking transformer with a three way switch can provide Line, Line - x and Line - 2x by using a CT transformer for areas with less than stable power.
    See Bucking (And Boosting) Transformers by Rod Elliott
    This Google Image Search give plenty options from utility to HiFi pretty.
    CletusB
    CletusB
    Post by CletusB Mon Jan 09, 2023 2:57 pm
    I'm located in the Caribbean (Trinidad) so I used what I could get my hands on locally for this project.  With our power company anything goes, got a plastics extrusion factory right opposite and other factories nearby. On the grid during the day it could be as low as 105V and at night when the factories are off-line as high as 128V. Not really fast changes or spikes, but rather inconsistent overall, right now for instance it's 118V at the outlet and my Servo Variac is holding nicely at the preset 115V)
    CletusB
    CletusB
    Post by CletusB Sat Apr 01, 2023 11:35 am
    Cletus’ Music System 2023
    (Continually Evolving)
    I never, ever get tired of listening to my system! cheers
    Speakers: DIY Altec A7 “Voice of the Theatre” fully braced  cabinets with additional Bullet Tweeter (a number of drivers expensive and cheap were tried with the enclosures [back then, used what I could find locally] until I found what showed promising results on the measurements and  was most pleasing to me sonically. I actually settled on some inexpensive drivers from American Audio, Sound Barrier and Pyle (woofer, midrange and bullet tweeter) and this was like 25-years ago. (back then, I had MLSSA software at my disposal for audio analysis)
    Crossover: DIY passive 2nd order, 3-way  (Dayton Capacitors, Inductors and L-Pads)
    Interconnect Cables: DIY Microphone shielded cable terminated with appropriate gold plated plugs
    Speaker Cables: DIY 12awg Copper 8ft
    Primary Power Amplifier (Tube): DIY  VTA ST-120 with KT-88 and Auto-bias
    Alternate Power Amplifier (MosFet): Alesis RA-500
    Preamp:   DIY Zero Gain Passive Attenuator and Wafer SW Rotary input selector
    Line Amp: FX Tube 01
    CD Deck: Pioneer PD-4500
    Reel to Reel: DIY restored  TEAC A3340S   (I use ATR Tape)
    Recording Line Amp: DIY Solid State with EQ and built-in 400Hz Sine Wave Oscillator
    Music Server / DAC: DIY Raspberry Pi3, Allo Boss, 2TB Hard-Drive (Synogy NAS Backup)
    Bluetooth Receiver: 1Mii B06Pro+ 5.1  with LDAC
    Power Management and Conditioning: DIY Latching Mains Power Conditioner with Surge/Spike/RFI Suppression, Servo Controlled Variac, and Linear 5V 3A power supply for RPi3 music server / DAC. Sequenced Soft-Start power-up for system devices. Z-Wave voice controlled power switch via  “Alexa”
    Music Player:  Volumio
    Remote Controller:  Dedicated Fangor 10” Android 11 Tablet
    Listening Room Size / Treatment: (W x L x H) 12’ x 36’ x 9’, Front Wall heavy drapes floor to Ceiling, rear wall light drapes floor to ceiling, Carpeted Floor, Fiberglass Acoustic Tile Ceiling, Bookshelves left and right.
    Dedicated Test Instrumentation: Room EQ Wizard (REW), miniDSP UMIK-1, Radio Shack SPL Meter
    Dale Stevens likes this post
      Current date/time is Mon May 06, 2024 11:07 pm
