by corndog71 Tue Jan 31, 2023 6:10 pm
Njrob wrote:I'm thinking it's a good idea but I don't know if my amp can handle the WS1 with thermistor If it is a healthy choice.
Bl vta st120 (2010?) Kt88 12at7
I trust Roy who says it's OK even without tdr.
Should I not worry and just plug it in?
Should I do the tdr?
Should I do the sds upgrade cap board?
I would think the WZ68 would be the proper option for a ST120. But the WS1 with thermistor will work too. The main differences are current limit and voltage drop. While the thermistor is good for creating a soft start it does nothing to the voltage. WZ68 has a lower current capacity (still plenty enough for the ST120) but has the same voltage drop as a 5AR4.
If your wall voltage runs over 122 then definitely consider the WZ68. Or you could do the yellow sheet mod and use any 5AR4. With higher wall voltage the 17 volt drop is better for the tubes.
For what it’s worth, on my custom built ST120 I used 2 1N4007 diodes in series on each leg of the high voltage secondary (red wires). I also used the TDR. But then I also plugged the amp into either a variac or bucking transformer to lower my higher wall voltage.
Either way you have options. The right answer mostly depends on your wall AC.
If your wall voltage is lower than 122 then the WS1 with thermistor should be fine.
The TDR is a neat option but I ended up taking it out when I rebuilt my amp for sale. I prefer the yellow sheet mod which allows for either solid state or tube rectifiers. TDR is for solid state rectifiers only.
Personally, I recommend the yellow sheet mod regardless of rectifier you end up with. It won’t hurt anything and actually protects tube rectifiers.
