    Your opinion on tubes for a PAS3 dynaco preamp
    carcy
    Your opinion on tubes for a PAS3 dynaco preamp  Empty Your opinion on tubes for a PAS3 dynaco preamp
    Post by carcy Wed Feb 01, 2023 7:58 am
    Hello guys ! I reach the end of ma PAS3 restoration... Phono board PC6 modification, adding a new cap board... I will create topics for these restorations...
    I'm waiting the alps pot from updatemydynaco, and I'll be ready for the tests !!!
    And the most important now... The tubes...
    I could read everywhere that it is interesting to use different tubes on the PC5 and PC6 boards... OK...
    What do you think about that ??
    I manage tu use this preamp in combination with a vinyle LP turntable...
    Which tubes would you recommend me ???
    Many thanks from France !
    Jean-Luc
    Your opinion on tubes for a PAS3 dynaco preamp  Empty Re: Your opinion on tubes for a PAS3 dynaco preamp
    Post by peterh Wed Feb 01, 2023 8:14 am
    carcy wrote:Hello guys ! I reach the end of ma PAS3 restoration... Phono board PC6 modification, adding a new cap board... I will create topics for these restorations...
    Jean-Luc
    JJ E83CC  on all positions.
    This is a framegrid tube, exactly as the TESLA / telefunken framegrid, low noise, linear
    and tight tolerances.
    And do make sure the riaa components are in accordiance with the Dynaco manual.
    carcy
    Post by carcy Wed Feb 01, 2023 8:26 am
    Hello Peter and many thanks for your answer !!
    And for the 12x4 tube, is there one tube better than another ?
    You scare me a little by saying "And do make sure the riaa components are in accordiance with the Dynaco manual." !!  Laughing Laughing
    In fact my PC6 board is modified according to curciaudio
    Your opinion on tubes for a PAS3 dynaco preamp  Curcia10
    Hey and just a last little question...
    I have these caps at 2700pf 500V +-5%...
    Your opinion on tubes for a PAS3 dynaco preamp  2700pf10
    Is it better or not than the 2 caps 2200pf and 470pf in parallel ?
    JL
    Post by peterh Wed Feb 01, 2023 9:30 am
    carcy wrote:Hello Peter and many thanks for your answer !!
    JL
    Have a look at audioregenesis where some
    myths about PAS riaa conformance has been spread.
    You might revert your rebuild :-(
    carcy
    Post by carcy Wed Feb 01, 2023 10:23 am
    Ho it is a sad new...
    Do you have any changes for me ?
    I do not understand all these schematics and explanations (i'm not in electronics !! lol).
    Does it means the original boards and components are better than all the mods ?
    Post by peterh Wed Feb 01, 2023 11:07 am
    carcy wrote:Ho it is a sad new...
    Yes. That is what George Ronnenkamp says according to the report. He also
    goes deep into the sugested mods both as simulations but also with actual
    measurments.
    carcy
    Post by carcy Wed Feb 01, 2023 11:25 am
    Crying or Very sad Crying or Very sad Crying or Very sad
    then I must reverse everything...
    -replace the 95.3k with original 100k resistors
    -replace the 2.2Mohm resistors with original 4.7M (or perhaps with 3.9Mohm as mentionned in the article :
    Your opinion on tubes for a PAS3 dynaco preamp  Resist10
    -restore the 68pf cap instead of the 820pf and rewire the PC6 to the selector switch...
    Your opinion on tubes for a PAS3 dynaco preamp  Imag4110
    -and replace (again) the wire shorts with 0.1µF and one of the yellow cap of 0.1µm into 0.05µF (the one below the tube)...
    Your opinion on tubes for a PAS3 dynaco preamp  Imag4111
    Where to find 750pf caps for the selector switch ? and 68pf (+/-2% ??)
    Post by Roy Mottram Wed Feb 01, 2023 3:20 pm
    680pF + 68pF = 748pF close enough to 750
      Current date/time is Sun Apr 28, 2024 9:47 am
