Well, still have a hum problem. Rewired all the grounds to one point. Made no difference. Checked all the tubes. All good. Don't know how well matched the EL's are. This is my second set of tubes as I replaced all my tube shortly after building this st70 because of hum problems. At that time it helped lower the level of the hum but it's still there. So using Jensens method of tracking down the source of the hum I determined it was the st70. Okay so with the st70 attached to my polk towers and shorting out the input I could hear nothing. But when I put the st70 on the bench and connected my bookcase klipsch there it was. The EL's I'm using are J&J. Are these any good? Could this be the source of my hum? Not balanced. The bias is set exactly to 1.57vdc on both sides. But if the tubes aren't matched how can you tell? Scope? Or could there be a dc offset sneaking in there? There has to be an explanation for this hum. It's been there to varying degrees since I built this unit. Any thoughts would be welcomed.
Kind Regards,
Paul
