Let me preface this buy saying I have read about 200 posts on hum.
I have a new build ST70. Everything is new. Transformers, tube sockets, tubes, bias circuit, can caps, resistors, etc.. all new components. Not a single old part on it. Using a Dynakit PC-3B board.
Fired the unit up and checked voltages and everything was to spec per the dynaco documentation. Used a variac to set voltage to 117 VAC and biased each side to 1.25 VDC.
Left side is dead quite. Not a single noise. Right side has a significant amount of hum. I went back over the wiring and all looks good. I rotated tubes (Tung Sol EL34, Tung Sol 5AR4 and NOS RCA 6U8G) and hum stays on the right side.
I shorted the RCA's and the hum gets louder. Also, I noticed that the impacted side has significantly less output by about a factor of half when hooked to a source.
Tonight I am going to hook up my signal generator and dummy loads and use a scope to try and pinpoint if there is a section in the amp that is producing the hum but I wanted to see if anyone has any other troubleshooting tips I should try. Especially with the dimished output which I think is a definite sign something is not right.
