+2
mantha3
baddog1946
6 posters
    Rectifier modification for the GZ34
    baddog1946
    baddog1946
    Rectifier modification for the GZ34 Empty Rectifier modification for the GZ34
    Post by baddog1946 Mon Oct 18, 2010 10:01 pm
    Hi all:
    I found these two versions of this rectifier mod for ST70's ising a GZ34 or equivalents on DIY threads and thought it would be of interest to those who have been having problems with tube rectifiers. Looks pretty simple and and easy. Both appear to be the same mod.
    baddog1946
    http://www.diytube.com/phpBB2/viewtopic.php?p=31759&sid=6cebd09b7841b53734767346943d0123
    Van Alstine version:
    For your information, we recently posted a small upgrade to our Ultimate 70, Ultravalve, and even stock Dyna St-70 amplifiers. All that is necessary is to install two 1N4007 diodes, one in series with each high voltage power transformer lead to the 5AR4 rectifier tube. The diodes will mount on unused 5AR4 socket pins. The purpose is to prolong the life of the rectifier by reducing the impact of cold hard turn-on AC voltage to the tube.We recommend this for any vacuum tube amp using a 5AR4 rectifier tube.[u]
    mantha3
    mantha3
    Rectifier modification for the GZ34 Empty Re: Rectifier modification for the GZ34
    Post by mantha3 Thu Dec 09, 2010 9:58 am
    I put this Mod in last night on my ST-120. This is real easy to do. I had the copper braid to clean up the De-solder the wires from 4 and 6. The two 1N4007 Diodes were under a buck.
    I put some $$ into a GZ34 so I thought it would be worth the time to do this mod. Put it in and back to sweet music.
    Here is a plan I got from the friendly people at Dynakit.
    Photobucket
    edgobb
    edgobb
    Post by edgobb Sun Jan 30, 2011 2:05 am
    After I did this mod the voltage readings on pins 4 and 6 decreased quite a bit...to about 203VAC. Pins 5 and 7, the pins with the PT leads, still test normal at about 379.5VAC (albeit a little high.)
    I assume this is normal?
    Ed
    Sal
    Sal
    Post by Sal Sun Jan 30, 2011 11:10 am
    After the diodes on pins 4 and 6 you have to set your meter to DC. You will measure pulsating DC before the filter capacitor, set your meter to DC and measure at pin 8 of the 5AR4 tube.
    Sal
    xlr8
    Post by xlr8 Fri Feb 04, 2011 3:48 pm
    Call me crazy, but I think the PT's in both of my 70's are running a tad cooler after this mod?
    Blitzen
    Blitzen
    Post by Blitzen Sun Feb 06, 2011 1:58 pm
    xlr8 wrote:Call me crazy, but I think the PT's in both of my 70's are running a tad cooler after this mod?
    Can anyone else confirm this? Does this mod take some load off the PT? You're still powering the rectifier filament...
      Current date/time is Fri Apr 26, 2024 5:54 am
