+2
WntrMute2
Tom
6 posters
    Fuse Question
    Tom
    Fuse Question Empty Fuse Question
    Post by Tom Wed Apr 20, 2011 6:44 pm
    OK, yet another dumb question.
    SP-8, passed the no-tube part of the smoke test last night.
    12.5V on the filament circuit w/out tubes.
    Went and got tubes for part II tonight but,
    plugged the unit in, powered on, and immediatly blew the fuse.
    No tubes in the sockets, just like last night.
    Looked at the fuse, it's a 1.25A and doesn't say slo-blow.
    I'll get some 1A slow blows and try again tomorrow but
    is it the fuse?
    Is there some other disaster I'm overlooking?
    Argh! Help! I have angst!
    Smile Tom
    (actually I didn't look up angst so I'm not sure if that's what I've got)
    WntrMute2
    WntrMute2
    Fuse Question Empty Re: Fuse Question
    Post by WntrMute2 Wed Apr 20, 2011 7:19 pm
    Yup, angst is what you've got all right.
    Tom
    Post by Tom Wed Apr 20, 2011 7:53 pm
    thanks mang,
    I was wondering....
    baddog1946
    baddog1946
    Post by baddog1946 Thu Apr 21, 2011 11:45 am
    Most likely a bad solder joint. Move the amp a little and it breaks or makes the connection. If it is blowing fuses then you need to check your build step by step.
    Almost always a mistake you made in the build or soldering. Get someone else to look at it sometimes helps because you keep making the same mistake or do not see the error yourself.
    Post by j beede Thu Apr 21, 2011 3:50 pm
    Sounds like you may be overlooking something as a one amp fuse should be fine as most tube preamps dissipate 20-40W.
    Post by Roy Mottram Thu Apr 21, 2011 9:32 pm
    SP8 can use a GMC-1 or a GMC-1.25 fuse, those are medium delay
    you've probably got a short or wiring error somewhere, or a shorted tube filament
    Tom
    Post by Tom Thu Apr 21, 2011 10:02 pm
    Thanks all.
    Went and got new fuses. Looked at everything for oops, found nothing.
    Put new fuse in, no tubes. Power up, worked fine.
    Power down, wiggle, jiggle, try to see if anything is wrong, nothing.
    Power up, fine! Power down, tubes in. Fine!
    Hook up to CD, music goes in one side, comes out the other. It's a miracle!
    Unplug CD, just the faintest bit of 60 cycle hum with vol all the way up.
    I'll need to work on that but caveat, it's playing through an old Technics integrated in the garage.
    Cd first, then SP8, then the Technics pre and power (can't separate them),
    so I have no idea if that's part of the hmmmmm.
    Will try with an independent power amp this weekend but
    in the mean time,
    Beers all around. Tell 'em I said so!
    Very Happy Tom
    Post by j beede Fri Apr 22, 2011 1:01 am
    You may want to do some power cycling and burn in using the garage system. Remeber that problems that go away by themselves can come back by themselves. Better to build up some confidence out in the garage rather than have an "event" while driving your Quad57s inside! I keep a pair of Radio Shack Minimus 77s and a NAD amp around just for this purpose.
    ...j
    Tom
    Post by Tom Fri Apr 22, 2011 7:41 am
    Good advice j. Thanks!
    Tom
    Post by Tom Wed Apr 27, 2011 7:09 pm
    OK, found the fuse blowing problem. Kinda.
    Was trying to find the minor ground loop hum and switching polarity of the plugs as Roy (I think) suggested in Ed's sp-12 thread.
    Old Technics integrated is serving as the amp during the garage phase. It's a two prong plug.
    Technics plug one side up - sp-8 blows fuse.
    Technics plug other side up, reversed polarity - sp-8 makes pretty music.
    I know I know, just keep the right side of the plug up Razz
    But maybe somebody could enlighten me on this condition and let me know if there's a common error I've made here?
    Thanks as always!
    Tom Cool
    Also, the ground loop hum is only evident when the Technics is cranked more than 1/2 way up. I can't wait to get the SP-8 on the real amp, that hum might just be invisible.
    Hmmmm. I guess that should be inaudible.
    Sal
    Sal
    Post by Sal Wed Apr 27, 2011 9:43 pm
    I just quickly read this post but if the fuse blows depending which way you plug in your Technics amp... Houston, we have a problem..
    You have a short somewhere, does the Technics amp have a capacitor from the line cord to ground, if so, that capacitor might have some serious leakage.
    Sal
    Tom
    Post by Tom Thu Apr 28, 2011 10:15 am
    Houston to Sal:
    Affirmative on the possiblity of the cap leak in the Technics.
    Rumbles and grumbles on power up and down.
    Will initiate diagnostic and workaround.
    Houston out.
    Smile Tom
      Current date/time is Fri Apr 26, 2024 1:51 pm
