    The Truth about the M125 Mono Blocks from a novice
    shaunst
    The Truth about the M125 Mono Blocks from a novice Empty The Truth about the M125 Mono Blocks from a novice
    Post by shaunst Mon Jun 13, 2011 3:55 pm
    So, let me start by giving you a quote I gave Bob in my first email:
    "I have little confidence these amps will actually work"
    Why? I am a complete novice and have not built anything electrical of this nature.
    My first M125 build was tough for me ..
    However, that being said, it is not impossible either, and a complete novice, with patience and upfront understanding of the level of effort required, can COMFORTABLY build these amps.
    Build Time: 1st amp - 20 hours, 2nd amp - 10 (maybe 12) hours. Much better on the second amp... experience, even a little, on soldering will help. 80% of your build time is soldering.... get an old radio and solder the bejessus out of it. Also, get TWO 30 watt soldering pencils, my biggest mistake was not moving over to a new iron when my soldering got messy and ugly.
    I finished my two block build in about 7 days, including pretty much solid over a weekend. I wish I had taken it slower... enjoyed the journey more. Biggest piece of advice if you are not a regular DIY electronics builder... SLOW DOWN, GO SLOW.
    Now, to my amazement, shock and AWE, BOTH of these amp fired up FIRST TIME and worked prefectly! Eating my words above! :0)
    As to the sound/quality/performance
    - The amps have been playing for 2 hours, so expect they will improve as everything 'settles in'
    - Cannot perceive much difference in triode mode?
    - The bass is much 'bigger' and much more noticeable. That's not to say it is boomey, or overpowering, but it is much fuller than on SS apms used before.
    - The stage width has DOUBLED - wow !, that's maybe the best part so far
    - Where as my previous amps distorted and failed when I pushed the volume to max, the M125 did not even flinch, no distortion... just DAMN loud !
    - Lastly, I drive directly from Wadia 21 to the amps and with no CD playing and volume on MAX, there is NO HUM, NOTHING... and I mean NOTHING, ear right up to the ribbons/cones... NOTHING... that's very nice, and certainly NO REFLECTION on the builders ability.. :0)
    All in all, I wanted tube mono's above 100w, and these for the price and 140w+ with KT120, are great.
    Would I recommend them? YES... just know what your getting into and be PATIENT.
    System:
    Wadia 21
    Carver AL III
    M 125 Monoblocks (WZ68/KT120x4)
    The Truth about the M125 Mono Blocks from a novice Empty Re: The Truth about the M125 Mono Blocks from a novice
    Post by Bob Latino Mon Jun 13, 2011 5:26 pm
    Hi Shaun,
    Thanks for your comments .. You are the FIRST complete novice to build the M-125's. You have proven that diligence in the end pays off.
    You don't need any real electrical knowlege to build the M-125's. As long as you can use hand tools, a soldering pencil and FOLLOW DIRECTIONS, you can build the M-125's AND (more importantly) the amps WILL WORK. I can understand that the first amp would take longer.
    Re: "the stage width doubled" ... Monoblocks by their very nature have greater signal isolation between the channels. This combined with the very low phase shift of these amps will translate into a much wider soundstage. When I play my own two M-125's here at home, I can sometimes on certain recordings hear sounds to the left of the left speaker and to the right of the right speaker. The soundstge is (sometimes) wider than the speaker placement. To be clear, this effect is not heard on all recordings and may not be noticeable on all music systems.
    Re:"there is NO HUM, NOTHING... and I mean NOTHING, ear right up to the ribbons/cones... NOTHING..." In the design of the M-125's careful attention was given to parts placement and wire routing. My friend from Boston with the test equipment measured about a 95 dB signal to noise ratio for the M-125.
    Re:"Where as my previous amps distorted and failed when I pushed the volume to max, the M125 did not even flinch, no distortion... just DAMN loud !" The amp is "rated" at 125 watts. With the KT-120 tubes you gain about 10 watts. When the amp is cranked up, each amp will go over 200 watts on peaks.
    j4570
    Post by j4570 Mon Jun 13, 2011 5:54 pm
    Shaun,
    Thanks for your review. Got any pictures?????
    I just finished a rebuild of an ST70, and I love it. I'll have to wait a while before upgrading to these though. Summertime is bleeding money time for me-vacations, etc.....
    It's nice to see amps rated CORRECTLY. I say that because many cheap amps are rated some weird way. This is why quality gear (in anything, electronics, cars, tools, etc.) always performs so much better. It's rated to a real standard, and not something arbitrary that makes it look good for the few seconds it can perform at that level. Fuze your speakers with that much power.....At least the tweeters.
    Congrats. Especially for a novice. I don't solder much, but have soldered for 30 years or so, and am good at that. And worked on old radios. So I thought rebuilding was a breeze, but I took my time, and it took probably 10-12 hours or so (probably underestimation) for the ST70, so your time seems fine to me. Look at it this way, if it should have took 20 hours, and you pay yourself $100/hr, that's $2000!!!!!! That's probably the most you made in 20 hours in a long time, it is for me......
    You done good.....
    Jason
    Newportcycle
    Post by Newportcycle Mon Jun 13, 2011 6:48 pm
    Thanks for that review, and congratulations on completing the build. I what way do you feel "underwhelmed" can you elaborate? Do you not feel there is equal detail to the previous SS amps? I'm not very familiar with the M125's is there a 4ohm hookup on them?
    mantha3
    mantha3
    Post by mantha3 Mon Jun 13, 2011 7:21 pm
    I think you are running KT120... What other tubes are you running. What kind of coupling caps are you running? The Russian PIOs?
    shaunst
    Post by shaunst Mon Jun 13, 2011 7:36 pm
    Hi, I decided on 4ohm hookup as the Carver AL III and the Apogee Duetta Sig's I have coming both suggested 4ohm to 200 watts odd on the amps.
    The M125's when I first listened to them seemed to be underpowered in comparison to my original setup which was:
    Bi amped: Adcom 5500 on base / Yaqin 2100 on mid and upper ribbons
    And, in a raw power comparison, they are... as there is 400 watts in the original system compared to the 125w+ in the M125's. BUT, at 75% power from the line source (Wadia 21 direct) the Adcom/Yaqin setup was screechy/tinny (that a word?) and would ware on the ears after an hour or so... However, the M125's at the same level, although they seem maybe a little 'less loud' they don't sound "screechy/tinny' when the volume goes up, and are definitely are much, much better sounding amps.
    Are the M125's better sounding than the Adcom/Yaqin setup? Yes.
    Are they $1800 better? I am going to say yes... because I am sitting here having played them for 5 hours at a good clip of volume and I don't have a head ache. I am lucky in that I can listen to music while I work, so I spend 30 hours a week listening to music (I do some work at least.. :0) ). So, for me... the quality difference is noticeable, so it is worth the money.
    And I suppose that's what it boils down to, I wanted 100w+ tube amps, and these are great for the price... and seem to be improving with every hour that passes.
    shaunst
    Post by shaunst Mon Jun 13, 2011 7:40 pm
    mantha3 wrote:I think you are running KT120... What other tubes are you running. What kind of coupling caps are you running? The Russian PIOs?
    Whatta when who?? Geesh... no idea?! Theres a gold one on the back with a whatsy majig on the front... ohh, no that's two whatsy majigs.. :0)
    Jokes aside!
    Standard set from Ebay...
    Rectifier: WZ68 (1) Weber Copper Rectifier
    Preamp/Driver: 12BH7GP (2) - EHX Gold Pin matched and balanced
    Power Amp: KT120 (4) - TungSol 60 watt super audio power amps
    Post by Bob Latino Mon Jun 13, 2011 7:52 pm
    Re: > "I think you are running KT120... What other tubes are you running. What kind of coupling caps are you running? The Russian PIOs?"
    All M-125 amps come with (as standard equipment) both power supply upgrade caps (4 X Low ESR Nichicon 100 uF caps) and matched sets of Russian PIO main coupling capacitors.
    mantha3
    mantha3
    Post by mantha3 Tue Jun 14, 2011 8:55 am
    Ahhh... Nice. I think it is a great idea to make the PIO caps and the power supply cap upgrade standard.
    shaunst,
    These amps will probably grow on you as the "burn in" time time on the caps and tubes passes. I think you won't hear the true sound till you have about 100 hours on the amp.
    Thanks for reporting on the build and on how you like these amps. I have the ST120 amp and I'd probaby have done these if they had been available. Oh well, enjoy the amps!
      Current date/time is Sat Apr 27, 2024 9:41 pm
