    Photos of the new Dynakit ST-70 I built
    Sal
    Sal
    Photos of the new Dynakit ST-70 I built Empty Photos of the new Dynakit ST-70 I built
    Post by Sal 7th July 2011, 11:19 pm
    A new customer of mine wanted the sound of an original ST-70 but didn't want to buy a used ST-70 of unknown origins so he purchased a Dynakit ST-70 kit from Kevin at Dynakitparts.com and had it shipped to me to build.
    I must say they way Kevin packed the components in individual bags with labels and supporting documentation, it makes it real easy for a novice to build the amp even if he has no concept of electronics but can follow directions.
    Here are 4 photos of the ST-70. I tested the amp with the 6GH8-7199 adapters as you can see in the picture but my customer brought his own tubes including 2 NOS Dynaco 7199 tubes that I installed when he picked up the amp.
    You can see I installed the BBCU-1 Bias Balanced upgrade also. The printed circuit board is the original color Dynaco used back then, I installed Orange Drops capacitors as the customer requested it from me although the coupling capacitors that came with the kit are of high quality.
    Regards,
    Sal
    Photos of the new Dynakit ST-70 I built Brian11
    Photos of the new Dynakit ST-70 I built Brian12
    Photos of the new Dynakit ST-70 I built Brian1a
    Photos of the new Dynakit ST-70 I built Brian6a
    Photos of the new Dynakit ST-70 I built Brian7a
    mantha3
    mantha3
    Photos of the new Dynakit ST-70 I built Empty Re: Photos of the new Dynakit ST-70 I built
    Post by mantha3 8th July 2011, 4:03 pm
    Sal,
    Solid build and I appreciate you taking the time to post the photos. I'd love to hear the more original (non VTA) amp just to hear it.
    Question - Where did you get the speaker terminals you have on that? I have a single Red and Black and I'd have to de-solder / solder the wire if I made a switch from the 8 ohm speakers I'm running now...
    Thanks man
    Andy
    Sal
    Sal
    Post by Sal 8th July 2011, 5:11 pm
    Thanks Andy,
    To my knowledge, Dynakitparts.com is the only company that sells the 4 terminal Banana speaker terminals.
    Regards,
    Sal
      Current date/time is 1st May 2024, 5:44 pm
