    Paper in oil coupling - decoupling capacitors
    metlmrk
    Paper in oil coupling - decoupling capacitors Empty Paper in oil coupling - decoupling capacitors
    Post by metlmrk Thu Sep 29, 2011 10:29 am
    Hi everybody, i didnt find any Info on a search so does anyone have any experience with Paper in oil coupling - decoupling capacitors for the PC-3 board? Im looking for feedback on the quality of the sound? I currently use oem value CDE caps. I thought it might be fun to try the Russian PIO caps perhaps in larger values ie .22 - .1mfd
    Thanks, Mark
    sailor
    Paper in oil coupling - decoupling capacitors Empty Re: Paper in oil coupling - decoupling capacitors
    Post by sailor Thu Sep 29, 2011 1:48 pm
    You might find this interesting.
    http://greygum.net/sbench/sbench102/caps.html
    Post by Roy Mottram Thu Sep 29, 2011 5:50 pm
    PIO caps should make a nice difference in the sound quality - you might also consider replacing the circuit with our VTA70 driver
      Current date/time is Sat Apr 27, 2024 1:05 am
