+38
rebellovw
fedoragent
Dale Stevens
KenGaler
Wharfcreek
Tubes4ever
rjpjnk
ejc
GreggW
gener8r
neali
Jim McShane
Pat R.
heyraz
dmtparker
MexicoMike
Ed Rosenberger
telefunking
scottlowe
guentherj2
ricohman
poconoman
burnedfingers
Feistygoat
mantha3
anbitet66
pmit2188
42 posters
    tube rectifier "yellow sheet" diode mod
    Seamus
    Seamus
    tube rectifier "yellow sheet" diode mod - Page 5 Empty Re: tube rectifier "yellow sheet" diode mod
    Post by Seamus Fri Oct 18, 2024 2:36 pm
    maltboy1 wrote:Is there any downside to adding diodes to the input and output? So, in other words, why not do both mods?
    Triple the parts increases the potential failure rate & cost.
    - drops more voltage
    - increases heat
    Both small, but both are 100% negative with zero positives
    Another flaw I thought for the 2x on the input is that if one fails, the amp is going to be running at half voltage. Not a good thing if the diode lets go under high load. The signal will be severely clipped until the amp is depowered. Might be hard on the tweeters.
      Current date/time is Mon Dec 09, 2024 10:06 pm
