    Pas3 distortion after bypassing tone controls
    intotubes
    intotubes
    Pas3 distortion after bypassing tone controls Empty Pas3 distortion after bypassing tone controls
    Post by intotubes Thu Sep 05, 2019 4:40 pm
    I bypassed the tone controls using http://www.audioregenesis.com/documents/PAS%20Tone%20Control%20Bypass.pdf after having not used it for a while.
    I also have an SDS Audio labs power supply board installed. All tubes test very good on my Sencore Mighty-Mite II
    I now have quite a bit of distortion playing records (into a ST70, new tubes).
    I measured voltages and found only 103 VDC on pin 1 of one of the 12AX7'S on PC6. Other voltage readings are pretty close to aim except maybe pin 6 of the 12AX7's on PC5 which are 191.5 and 201.
    Is that enough to cause problems?
    -Mark
    Pas3 distortion after bypassing tone controls Empty Re: Pas3 distortion after bypassing tone controls
    Post by peterh Thu Sep 05, 2019 5:41 pm
    intotubes wrote:I bypassed the tone controls using http://www.audioregenesis.com/documents/PAS%20Tone%20Control%20Bypass.pdf after having not used it for a while.
    -Mark
    No, voltages seem to be withing "margins".
    No other chages ?
    If the distortion is only when playing vinyl i suggest you replace the ecc83 on pc6 with new ones.
    And, clean the needle !!
    Post by Roy Mottram Thu Sep 05, 2019 7:51 pm
    also clean the selector switch, especially if it's an original !
    solderblob
    solderblob
    Post by solderblob Thu Sep 05, 2019 11:52 pm
    -Mark
    I had a similar situation a few months ago.  Turns out my cartridge was gummed up.  I cleaned it with water and a brush and the distortion was gone.
    Dave
    intotubes
    intotubes
    Post by intotubes Fri Sep 06, 2019 7:41 pm
    Thanks for all the help! I have some things to try now. I have a second cartridge/headshell I can try as well. One thing I feel a little stupid about is I didn't try a CD to try and isolate the problem.
    -Mark
    *Update*
    Tried a CD, no distortion. Cleaned the needle, played an LP. Sounds good.
    So I don't know. Dirty needle? I removed the tubes an reinserted a couple times. Dirty sockets? It's a new preamp/amp/speaker combo, maybe not used to the sound? Seems like there's more gain (loudness) than before but maybe I'm comparing amps. I haven't got many miles on the ST70 with KT77's so its a lot more power than I'm used to with the PAS3. Also the JBL L300 have a different sound than my Model 19's. I'd say this set up is brighter than the Fisher KX-200/Model 19 combo. Both set ups sound pretty good though.
    Thanks for the advice!
    -Mark
      Current date/time is Mon Nov 18, 2024 10:36 am
