    Adcom cartridge rebuild?
    wildiowa
    Adcom cartridge rebuild? Empty Adcom cartridge rebuild?
    Post by wildiowa Tue Feb 02, 2021 4:02 pm
    I recently inherited an Adcom cartridge that was still on a tonearm, model XC/LTII. From what I read this was a high end cart in its day. I played it through my system a couple times but the stylus is seriously compromised. It looks like this does not have a replaceable stylus. Are these able to be rebuilt? Is it worth it or better to get another cartridge? Thanks.
    Adcom cartridge rebuild? Empty Adcom Cartridge Model XC/LTII
    Post by stewdan Tue Feb 02, 2021 4:23 pm
    Hi ---- I did a google search on your cartridge, and someone used SoundSmith to "rebuild their cartridge".
    Might be a possibility for you??!!
    Stew
    wildiowa
    Adcom cartridge rebuild? Empty Re: Adcom cartridge rebuild?
    Post by wildiowa Tue Feb 02, 2021 4:43 pm
    Many thanks. I guess I am used to lower end carts that have a replaceable stylus. I did not think too much about it but it appears to be a good one maybe a couple hundred bucks is a good investment. I got a blue Ortofon to replace this and thought I was really moving up in the world. Sending it to a place in NJ today for an estimate.
    KD6AR
    Post by KD6AR Tue Feb 02, 2021 9:43 pm
    Read up on the difference between moving magnet and moving coil cartridges.
    wildiowa
    Post by wildiowa Wed Feb 03, 2021 12:55 pm
    Got it. The rebuild is almost as much as the original cost but I think I will go for it. It appears moving coil cartridges do not have a replaceable stylus.
    solderblob
    solderblob
    Post by solderblob Thu Feb 04, 2021 2:13 pm
    I have an Adcom XC-LTII that I bought in 1984. I quit using it when I broke the cantilever...and it's been in my "box of broken cartridges" ever since.
    It's a high output moving coil meaning you can input it into a MM phono input and don't need a step-up transformer or high gain phono stage.  The XC stands for cross coil meaning the coils are mounted on the cantilever at 45 degrees.  My system has changed a lot since then, but I recall that I liked the cartridge.
    dave
      Current date/time is Mon Nov 25, 2024 10:10 pm
