    Received my Solid State VTA Rectifier kit today
    Rbertalotto
    Received my Solid State VTA Rectifier kit today Empty Received my Solid State VTA Rectifier kit today
    Post by Rbertalotto Mon Mar 08, 2021 3:38 pm
    Tom Pickett likes this post
    alanhuth
    Received my Solid State VTA Rectifier kit today Empty Re: Received my Solid State VTA Rectifier kit today
    Post by alanhuth Thu Jun 10, 2021 8:07 pm
    Did this rectifier work out for you?
    I notice the Weber has 2 18-ohm, 10 watt resistors in series in theirs. this has no resistor at all. I’d like someone to explain whether they are needed here or not?
    Rbertalotto
    Post by Rbertalotto Thu Jun 10, 2021 8:28 pm
    So far so good. Working great!
    alanhuth
    Post by alanhuth Fri Jun 11, 2021 10:49 am
    Any idea why it doesn't need the resistors the Weber has?
    Rec
    Post by Rec Sat Jun 12, 2021 7:45 am
    Weber sells multiple models. I have been using (and have repaired) a couple of WZ68 and a WS1. The WS68 has the 2x18 ohm resistor and the inrush resistor. The WS1 has no resistors and the inrush delay is optional (eg its just a bunch of diodes). The Webers use 2 series diodes per leg for some reason.
    The resistor mimics the voltage drop of a tube rectifier to get your B+ more in 'tube range'. WS1 will have a higher B+. So this "kit" is more like the WS1. You accommodate these differences with bias setting on your amp.
    alanhuth
    Post by alanhuth Tue Jun 15, 2021 10:45 am
    The kit also has a thermistor. Doesn't that affect inrush current?
    Rec
    Post by Rec Wed Jun 16, 2021 7:48 am
    Yes. High resistance at starting (to limit current), lowers as it heats up and conducts. There was one in my WS1 (which I ordered with delay) and also the WZ68. The kit will have a short startup delay.
      Current date/time is Tue Nov 26, 2024 8:50 am
