+4
markeby
LeGrace
Jlskey
8 posters
    VTA ST 120 needs surgery!
    Jlskey
    VTA ST 120 needs surgery! Empty VTA ST 120 needs surgery!
    Post by Jlskey Thu Apr 07, 2022 12:49 pm
    I built a vta st 120 from a Mr Latino kit a year and a half ago.  Great build experience and a fantastic listening experience!
    It’s been running:  4 sovtek 6550s, a tung sol 5ar7 and electro harmonix 12au7 as drivers.
    Amp was running great until a few weeks ago.  Turned the record, went to grab a beer and when I came back the lights were out on all tubes and wouldn’t light back up.  I powered it off for a bit and then powered it back on.  No lights.  A fuse was blown and it wouldn’t take any bias.  Multimeter was showing 000.
    Later on I replaced the fuse and Figured it was the rectifier.  I went back into the amp and switched the voltage line since my voltage was reading more consistently at 122 over the course of a few days.  Removed black and white wire from the first prong of the on switch and soldered on the black and yellow.  After closing her up I followed the original build instructions and put the driver tubes in and powered up.  They lit up so on to next step, powered off and put in the rectifier and the left channel power tubes and powered on after a few minutes and everything lit up.  Started to bias the left channel and whereas it’s took a bias adjustment it was a little harder and it varied a lot more than normal.  Turned amp off, put in right channel tubes and after a bit powered it on.  Started to try to bias it and it read 000, amp started making some noises and then I was treated to a light show. The right channel ones seemed to be more red and the rectifier glowed bright white before I heard a popping sound from
    It and then everything went dark like the first time.
    I’m already planning on opening her back up and going over all the solder  joints; replacing all of the tubes.  But I also wanted to see if there was anything else I should be looking for. Maybe the bias pots?  Resistors?  I’m all ears!  Fairly new to these matters so please feel free to mention anything you all think would help.
    VTA ST 120 needs surgery! Empty Re: VTA ST 120 needs surgery!
    Post by peterh Thu Apr 07, 2022 1:12 pm
    Jlskey wrote:I built a vta st 120 from a Mr Latino kit a year and a half ago.  Great build experience and a fantastic listening experience!
    Check the 10ohm resistors between 6550 cathode and ground. A tube that has
    been "flashing" will easily take the resistor out ( this is deliberately to save the transformer)
    If bad resistor found, replace with 10 ohm 1w film resistor and junk the tube that was in
    that place ( you probably will junk both tubes on that side and replace with a matched pair)
    The rectifier is junk, once flashed it it no longer reliable. When at it, add the "yellow sheet mod" where two 1n4007 diodes are connected in series with the anodes,
    If no 10 ohm resistors are bad the original cause could be the rectifier itself ( which you replace)
    or the can cap . If you cannot test the can cap and the fuse blows again you should
    replace the can cap too.
    Jlskey
    Post by Jlskey Thu Apr 07, 2022 3:35 pm
    What are you referring to when you say ‘can cap’? Thank you for your suggestions!
    LeGrace
    LeGrace
    Post by LeGrace Thu Apr 07, 2022 3:41 pm
    Not familiar with 5ar7 rectifier, do you actually mean 5ar4?
    Jlskey
    Post by Jlskey Thu Apr 07, 2022 3:46 pm
    LeGrace wrote:Not familiar with 5ar7 rectifier, do you actually mean 5ar4?
    I mistyped. It’s a 5ar4.
    LeGrace
    LeGrace
    Post by LeGrace Thu Apr 07, 2022 4:02 pm
    5ar4 failing is common issue. Replace or even better replace with WZ68 copper top.
    Jlskey
    Post by Jlskey Thu Apr 07, 2022 4:57 pm
    LeGrace wrote:5ar4 failing is common issue. Replace or even better replace with WZ68 copper top.
    Thank you! Yes I’ve read as much. But I’m curious what underlying issue may have caused the second 5ar4 to fail so quickly and spectacularly
    Jlskey
    Post by Jlskey Thu Apr 07, 2022 5:46 pm
    I think I see what you mean by can cap. Are you referring to the 550 volt Authenticap that I believe Bob calls the ‘quad cap’. My command of the industry lingo is a little weak.
    LeGrace
    LeGrace
    Post by LeGrace Thu Apr 07, 2022 6:58 pm
    5ar4 is underlying issue, failing quickly in these amps is common.
    Post by peterh Fri Apr 08, 2022 2:44 am
    Yes, that is what i was referring to.
    Post by peterh Fri Apr 08, 2022 3:24 am
    After replacing 5ar4 and any repairs of resistors changing power tubs etc turn all 4 bias
    adjustment pots fully anti-clockwise ( minimum current on all tubes ) . Reason for this is
    that the 5ar4 is operating on the brink of it's capacity, 2 6550 tubes drawing excess current
    can easily destroy the 5ar4. A 5ar4 that has "flashed" is broken and cannot be trusted.
    When powered on and warmed up, slowly start adjusting bias to normal level according to the
    build description.
    Jlskey
    Post by Jlskey Sun Apr 10, 2022 7:16 pm
    peterh wrote:After replacing 5ar4 and any repairs of resistors changing power tubs etc turn all 4 bias
    build description.
    Sounds good. Will certainly replace the rectifier tube, also the power tubes on the right channel. But what are your thoughts on the driver tubes and the power tubes on the left channel? Should I just suck it up and get a matched quad? I reckon the left channel probably has had similar problems and I won’t be able to get the same
    Brand of tubes for the right channel. Would probably get electro harmonix to pair with the remaining sov tek 6550. Don’t really like mixing brands.
    Post by peterh Mon Apr 11, 2022 1:48 am
    build description.
    Driver tubes should be ok ( whatever happens to them they won't kill the fuse)
    As for tubes, JJ KT88 is the best you can get and they are not made in russia.
    eurotubes.com has them
    markeby
    markeby
    Post by markeby Sun Apr 17, 2022 2:14 pm
    I have tried the JJ and Genalex KT88 tubes.  This kinda sucks but I now have the best sounding tubes in my VTA ST120 and they ar Svetlana KT88s.  My wife even noticed how sweeter the highs and lows are with these tubes.  I had only bought them because of the tube shortage that was about to happen two months ago.  I got lucky from a guy named Doug who still has a lot of tubes available at decent prices.
    Gabriel
    Post by Gabriel Sun Apr 17, 2022 3:32 pm
    Hi
    I recently built the ST120.
    I initially used. Solid state rectifier, wz68? And Genalex Kt88 Gold lion.
    Several minor issues resulting from an incorrect power transformer and a solid state rectifier which became extremely hot when the amp was switched on.
    I ditched the solid state rectifier, the TDR board and replaced the solid state rectifier with a 5u4gb.
    No issues so far, although the power transformer wArms up when the amp is switched on.
    I don’t trust the solid state rectifier, W brand.
    markeby
    markeby
    Post by markeby Sun Apr 17, 2022 5:18 pm
    I have been using a Telefunken GZ34-TK without any problems. I stayed away for the 5U4GB because it has a 3 amp filament vs the 2 amp on the GZ34-TK (and also 5AR4). I believe my instructions indicated a 5AR4. Both the 5AR4 and GZ34-TK are exactly the same. The 5AR$ is the U.S. designation and the GZ34-TK is the British designation.
    Jlskey
    Post by Jlskey Sun Apr 17, 2022 6:40 pm
    markeby wrote:I have been using a Telefunken GZ34-TK without any problems.  I stayed away for the 5U4GB because it has a 3 amp filament vs the 2 amp on the GZ34-TK (and also 5AR4).  I believe my instructions indicated a 5AR4.  Both the 5AR4 and GZ34-TK are exactly the same.  The 5AR$ is the U.S. designation and the GZ34-TK is the British designation.
    Good to know!
    Jlskey
    Post by Jlskey Sun Apr 17, 2022 6:58 pm
    In some other posts I’m seeing references to “open pins”. Does this have to do with a poor solder connection?
    Tubes4ever
    Tubes4ever
    Post by Tubes4ever Sun Apr 17, 2022 9:14 pm
    Just an informational note, the VTA 120 transformer is designed for up to 4 amps on the 5V winding. You can use a 5u4GB with no problems. I got this answer directly from Bob Latino.
    Gabriel likes this post
    Gabriel
    Post by Gabriel Sun Apr 17, 2022 10:32 pm
    Tubes4ever wrote:Just an informational note, the VTA 120 transformer is designed for up to 4 amps on the 5V winding. You can use a 5u4GB with no problems.  I got this answer directly from Bob Latino.
    Good to know a 5U4GB is ok.
    I assume the power transformer will run hotter because of the higher amps?
    The only reason I use the 5U4GB is that it’s one if the cheapest rectifier tubes.
    I use the EH tube which I was told is a bulletproof design.
    One day, I intend to use a 5AR, Preferably the Genalex Gold Lion which I can purchase for $120 AUD.
    The EH 5U4GB was $70 AUD.
    I wonder how this compares with prices in the USA.
    You guys have much more product choice than Australia…
    Jlskey
    Post by Jlskey Sun Apr 17, 2022 11:10 pm
    So while working on some of the solder points on the pcb board (in an effort to make sure the connections were good) I accidentally seemed to dislodge the metal coating on one of the holes. This was the hole that took the red/black wire from the power transformer to the underside of the pcb to the hole marked bias (right next to the bias diode). I figure since it’s a ground it should be ok but wanted to post here to see if it was going to be an issue.
    Jlskey
    Post by Jlskey Mon Apr 18, 2022 2:14 pm
    In my continued quest for reviving this puppy I’m going to test the quad cap. I know I need to get a cap meter (on the way), and that I need to remove it from the circuit (remove all other connections), but beyond that I’m lost.
    Jlskey
    Post by Jlskey Mon Apr 18, 2022 11:59 pm
    Used my newly obtained cap meter to measure the quad cap and it was in working order. Still curious if anyone knows anything about my post below on the red and black power transformer cord to the pcb board. Thanks everyone!!
    Post by Bob Latino Tue Apr 19, 2022 8:10 am
    When the amp is on > the eyelet where the red/black wire connects to the driver board should measure about 50 to 60 volts AC to chassis ground. Note - that red/black wire from the transformer is part of the bias system. The 55 volts AC is then sent to the banded side if the diode. What comes out of the OTHER side of the diode is about -75 volts DC. This negative DC voltage is then padded down with the 4 bias pots to get a lower negative DC voltage which is injected on to pin # 6 on each output tube and then through a 1000 ohm resistor to pin # 5 to bias all four output tubes. This negative DC voltage keeps the 4 output tubes under control.
    Jlskey
    Post by Jlskey Tue Apr 19, 2022 8:37 am
    Thank you Mr Latino. When performing said voltage check are any of the tubes in?
    Second, is it a problem that I seemed to dislodge the metal coating on the eyelet where the red/black wire connects to the pcb board?
      Current date/time is Tue Nov 26, 2024 6:09 am
