Hello Gang!
As you can see the wood shop is owned by 27 years of crafting and designing products with wood.
This will compose 1 enclosure kit:
Wood Chassis Size: 13W x 10D x 3H inches
Wood Detail
Fabricate (2) frames Heavy duty construction hand selected quarter sawn white ash. Both units from single boards.
Chassis is 0.778 inches thick (19.8 mm). Rebated for top and bottom plates. Mitre joints reinforced with biscuits and corner blocks. Designed to handle heavy components.
Drilled for inserts, drill and routed for rear access panel, chamfered edges.
Sanded to 150 grit and finished with bee wax.
Top Plate
Top panel available in a choice of Polished Multipurpose 6061 Aluminum Sheet or Stailess Still like mirror.
Top chassis is thick enough to support heavy transformers without bowing.
0.08” (2 mm) thick
Top plate comes with option of Dynaco or Edcor transformers
Top plate also accommodates 1 main switch cut out
Ready cut outs for HALG ST-35 board
Bottom plate
Designed with cut outs to proper ventilate the amplifier.
0.08” (2 mm) thick
Includes four large round rubber feet (0.75” dia. x 0.56” high) with mounting hardware into
inserts to avoid wood damage.
Back plate
Designed with cut outs to accommodate RCA inputs, banana outputs, Potentiometer (Vol), 110/220V switch, main input AC filter.
0.08” (2 mm) thick
Screws:
8 x 316 Stainless Steel Button Head Hex Drive Screw, Super-Corrosion-Resistant, 8-32 Thread Size, 7/16" Long
