    Ph 14 phone amp
    Jim
    Ph 14 phone amp Empty Ph 14 phone amp
    Post by Jim Thu May 11, 2023 1:36 pm
    Which tube or tubes  affects the sound the most in the in PH 14
    Ph 14 phone amp Empty Re: Ph 14 phone amp
    Post by Roy Mottram Sun May 28, 2023 9:12 pm
    there are 3 tubes in a PH14, the tube closest to the input is always the most important and should be tested for low-noise,
    most tube dealers offer this option.
    Also in some cases the PH14 has more than usual gain, so replacing either the first or all three tubes with 5751 works very well
    Jim
    Post by Jim Mon May 29, 2023 8:00 am
    Thanks you for that.
      Similar topics
      Current date/time is Fri Nov 22, 2024 1:01 am
