    VTA ST-120
    stelian99
    VTA ST-120 Empty VTA ST-120
    Post by stelian99 Fri Nov 17, 2023 2:33 am
    Hello guys,
    I bought my VTA ST-120 in February 2021 from Bob with the following options:
    VTA ST-120 amp wired with no tubes
    220/240 volt power transformer wired in
    Both capacitor upgrades
    Stepped attenuator wired in
    TDR wired in
    Triode/pentode switching kit
    As tubes, I'm using:
    4 x KT 120
    1 x Mullard GZ34
    1 x 12BH7A
    2 x Genalex 12AU7
    I saw on tubes4hifi website that are couple of upgrades for the amp:
    - dual rectifier mod
    - Bias display (replace octal socket) For use with VTA driver board only
    Do you recommend one of these as an upgrade?
    I want also to add an autobias board. Do you recommend any model?
    My room is not big, it's around 475 square feet.
    At this time I'm running a pair of A20 speakers which I like very much, but in the near feature I want to change with a pair of standfloors, something like B&W 703, Klipsch RF 63 or something like that.
    I read about for tube amps, the sensitivity of speakers must be higher than 90 db. Even for ST-120?
    I'm not listening loud, I just love the quality over quantity Smile. As music I listen mainly electronic music (chill, progressive house, deep house) and jazz.
    VTA ST-120 JnqTDXV
    VTA ST-120 JnqTtzQ
    Brap
    Brap
    VTA ST-120 Empty Re: VTA ST-120
    Post by Brap Fri Nov 17, 2023 1:12 pm
    Based on my experience egarding the sensitivity of speakers with a VTA, more efficient speaker is not really required. I had Klipsch Fortes, Klipschorns, Zu Druids and no run a pair of Fritz Carerra Be bookshelves on stands I truly love and everone is amazed at. I have a VTA ST-70. The Klipsch's we ranging form 96-103 SPL and the Fritzies come in around 88. The coparison to SPL an sound is another topic and very individual.
    Did the panel meter mod and its a very nice addition. Get some window tint, grade 35 darkness (scraps from a window tint shop) for the Lexan so you don't see the meters when turned off. Dan is working on upgrading the kit with potentially darker Lexan. The blue displays are nice a subtle. For bias setting, I will install panel mount test points for a DMM since it is a bit more accurate. However, these displays make the look of a VTA very appealing versus the old Dynaco preamp sockets and are good indictors if something goes wonky. Highly recommend.
    I've thought of building a VTA ST-120 but its strictly a want not a need. Really enjoy my ST-70 set-up and so does everyone else. However, if I were to do that I would definately to the dual rectifier mod and panel meters with self installed panel jacks for bias adjustments.
    Hope that helps.
    smoorenc
    Post by smoorenc Sat Nov 18, 2023 8:22 am
    I am glad i did both upgrades.
    VTA ST-120 Tubes210
    VTA ST-120 Tubes%202-X2
    MechEngVic likes this post
    itrfguy
    itrfguy
    Post by itrfguy Wed Nov 22, 2023 10:42 am
    Nice looking amp! I'm glad my digital bias display is such a hit!
    Briansilcox likes this post
    Brap
    Brap
    Post by Brap Wed Nov 22, 2023 11:02 am
    Love the powder coat if that it what it is. Nice craftsmanship indeed all around. I like my panel meters on my ST-70. Had to remove the resistor to eliminate some stray pulsating / flickering of the dispalys but all good now. Also added test plugs for a DMM. Great addition of the displays, well worth it.
    smoorenc
    Post by smoorenc Wed Nov 22, 2023 2:09 pm
    Brap wrote:Love the powder coat if that it what it is.  Nice craftsmanship indeed all around. I like my panel meters on my ST-70. Had to remove the resistor to eliminate some stray pulsating / flickering of the dispays but all good now.  Also added test plugs for a DMM.  Great addition of the displays, well worth it.
    I took the transformer sides off and had them powered coated, also the case and knobs. I made a SP-14 Pre Amp and color powder coat matched it.
    VTA ST-120 VTA%20SP-14%20Pre%20Amp-X2
      Current date/time is Wed Oct 09, 2024 3:47 am
