The ST-120 recapping went well but now have crackling noise in the R ch. Progressively gets worse and right channel sound is low and distorted. I see no error in rework recently performed to replace the electrolytics. Basic troubleshooting reveals 410V on the plates of the right channel phase inverter. Left channel looks normal around 225V.
Seems the high plate voltage indicates the 12AU7 phase inverter is not drawing current. Probing points to the LM334 constant current device in the phase inverter cathode circuit. Have some LM334s on order.
The noise sure sounds like a faulty capacitor popping or flaky tube so spent time exploring what I did recently to the circuit. But high plate voltage tells me the phase inverter 12AU7 is drawing little to no current. I now see why the board electrolytics are rated 400V. If the tubes draw no current then no voltage drop across the B+ resistor feeds to the tube circuits. The new Nichicon UCY board caps are rated 420V and are holding up well.
