    unstable bias M-125 monoblock
    Gerry Borghesi
    unstable bias M-125 monoblock Empty unstable bias M-125 monoblock
    Post by Gerry Borghesi Sun Aug 25, 2024 6:52 am
    One of my M-125s (output tubes KT-120) has developed an unstable bias, with 4 tubes in place, I can increase bias to about 0.4v and then the reading becomes unstable. Tubes all tested (e-tracer) and good. With speakers connected I get a 4 beats a second sound. Quad cap is good an no other obvious faults - thoughts welcome!
    Seamus
    Seamus
    unstable bias M-125 monoblock Empty Re: unstable bias M-125 monoblock
    Post by Seamus Sun Sep 08, 2024 5:13 pm
    What happens with one tube per side?
    Did you build the amp?
    Have you checked for a poor solder connection on the driver board?
    If you fiddle with bias a lot, the pot could be shot.
    Cermet pots have a rated life of about 200 cycles.
    If you replace the pots, use multi-turn as they are easier to adjust
    Bourns 3339P-1-503LF
    Last edited by Seamus on Sun Sep 08, 2024 5:14 pm; edited 1 time in total (Reason for editing : add line)
      Current date/time is Thu Nov 21, 2024 1:21 pm
