    Super Rectifier For ST-120
    jimmytamp
    jimmytamp
    Super Rectifier For ST-120 Empty Super Rectifier For ST-120
    Post by jimmytamp Mon Sep 23, 2024 2:49 am
    Hi All,
    I came across to this super rectifier from Space Tech Lab in Canada:
    https://space-tech-lab.com/Accessories/Super_Rectifiers.php
    My questions are:
    1. Has anybody tried this super rectifier in their system?
    2. Is it even possible to use this on the ST-120 with single rectifier (mine is 2013 version built by Bob) without affecting the quad cap?
    I asked questions to the seller (Space Tech Lab) and they said it’s possible with the use of the “full wave rectification” version (2x tubes with one rectifier socket connecter).
    I just want to have some advise from here the forum before I pull the trigger.
    Thanks in advance
    Jimmy
    Rec
    Super Rectifier For ST-120 Empty Re: Super Rectifier For ST-120
    Post by Rec Mon Sep 23, 2024 5:59 pm
    I’ve looked at this, there is a big thread touting its virtues on the decware forums.
    If it can handle the current, it just offloads rectification to exotic triodes. It either wires grid to plate or the cathode (I can’t recall) to make the diode. Some older amps I’ve seen have an 845 based rectifiers.
    It’s a cool way to roll rectifiers i guess. The interior shots that I saw did not impress me. Ie it didn’t look very robust build quality wise. The choke version adds a choke after “super” rectification, which might smooth dc, drop your b+, or mess with your power supply.
    I have no experience with this. I’d suggest taking a look at the decware forums. Hifi cave YouTube has a bunch of videos. Mostly on single ended amps. My main concern would be current handling of the “rectifiers”. Good luck and will be interested to see if anyone else has experience.
    Not too hard to build one for that matter.
    jimmytamp
    jimmytamp
    Post by jimmytamp Tue Sep 24, 2024 10:58 pm
    Hi Rec,
    Thank you for your reply, really appreciate it. I also would be careful before pull the trigger.
    Cheers..
    markeby
    markeby
    Post by markeby Fri Oct 04, 2024 1:45 pm
    I have seen and played with many rectifier designs. They look cool. I don't believe that they would improve the sound much, it at all and for that price without more build details, I am even more skeptical. Replacing the single rectifier tube in a ST-120 with dual rectifiers would likely work just as well for a lot less cost. I found a photo of the the inside wiring of one of those and I was even less impressed. My test builds look much better than that. Save your money for proven improvements like dual tube rectifier mods.
    jimmytamp likes this post
    jimmytamp
    jimmytamp
    Post by jimmytamp Sat Oct 05, 2024 4:54 pm
    Hi Mark,
    Thanks for the feedback, really appreciate it.
    Jimmy
      Current date/time is Thu Nov 21, 2024 1:30 pm
